Old 11-20-2012, 09:21 PM
Dodgeman5 Dodgeman5 is offline
Vehicle: 2011 dodge ram 1500 sport
Dodgeman5 is on a distinguished road
Default Nitto trail grapplers or toyo open country mt's
I have made up my mind on pretty much everything I am getting for my 2011 sport. The list is rcx 6" lift, bilstein 5100 front shocks, 1.5" tgc rear coil spacer, and fuel hostage 20x9 rims in black with 0 offset. Then there is the tires which I can't make up my mind. It's between nitto trail grapplers (37x12.5x20) or toyo open country mt's in (37x13.5x20). Suggestions please
Old 11-21-2012, 01:05 AM
Rep:1797
VERY SIMILAR TIRES!!!!
Both pretty quiet (Toyo's quieter of the 2)
Both wear evenly and last long
Made by the same company
Both have great sidewalks (Trails look slightly more aggressive)
It comes down to which do you think looks better and which one is cheaper.
Doesn't help, but they are so damn similar
Old 11-21-2012, 08:19 AM
Well I am leaning towards toyo cause I can get them for cheaper but the fact that they are wider and will stick out that much farther might be an issue
Old 11-21-2012, 09:17 AM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
I love my toyos. I got 35s and as far as sticking out I have 1.5" spacers all around and I'm not rubbing anywhere. But you should be fine either way you go
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
Old 11-21-2012, 09:23 AM
white4x4's Avatar
white4x4 white4x4 is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:80
white4x4 will become famous soon enough
I like the toyo's, I'm on my second set of them, my first set I sold with 20k miles on them an they still have about 50% life left on em and now my second set is just as good an try done even stick out to far and I got a -24 offset on my wheels, so I'd say hands down toyo's
Old 11-21-2012, 09:45 AM
Rep:1797
Its wider by 1" and only 1/2 of that will stick out.
On a 20x9, it will still be tucked close to the truck and you will not notice the difference even if a truck right beside you had the same rim except with Trails
Old 11-21-2012, 11:41 AM
Toyo's it is then and I know I asked this before but with the 20x9(0 offset) there should be no rubbing with 6" lift and bilsteins?
Old 11-21-2012, 11:42 AM
Rep:1797
Nope!
You will not have any issues.
I have 20x9, 0 offset and 37" Nitto Trail and I have a good 1" from the A arm and anything else.
You'll be 1/2" closer and still be good.
Old 11-21-2012, 12:18 PM
Grubrunner's Avatar
Rep:3883
Toyo's are now a dime-a-dozen these days as just about every hiked truck has them. Back as little as 5-7YRS ago they were like dinosaur droppings and you were the shizzle if you had them.
When all is said n' done, IMHO, they are still the very best Mud Terrains on the market today in all areas.
Highly recommended from an ex-owner.
Grub out!
Old 11-21-2012, 12:25 PM
Rep:1797
To add to what Grubrunner (great feedback) said. These are probably the best all around tire out there.
They act and ride like an AT tire
