Old 11-21-2012, 05:42 AM
redshift5 redshift5 is offline
Vehicle: 1996
Trim Level: 4x4
Color: Flat Black
redshift5 is on a distinguished road
Default How do i replace sparkplugs on my 2011
My 2011 Ram has a 4.7 engine in it. Does anyone know how to replace the plugs? is it easy? were are they?
Old 11-21-2012, 07:18 AM
Grubrunner's Avatar
Rep:3883
See if the clip below answers your questions...
http://m.youtube.com/#/watch?v=Nf9BX...%3DNf9BXdO6G98
Grub out!
Old 11-25-2012, 01:29 PM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
letsjet is on a distinguished road
I specifically bought my second 2011 4.7L for ease of self maintenance. I changed the plugs on my previous 2005 4.7L. It's pretty easy, as long as you have the correct tools. It's all working on top the engine, just make sure you have anti seize for the plugs, and a spark plug socket that holds the plug in to it. My 2011 has 22K so I'll be doing it on that engine when its time. It's just nuts and bolts mechanics.
2014 Ram 1500 Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Hemi Orange Pearlcoat
2010 Dodge Challenger R/T Classic Furious Fuchsia 6 spd
Old 07-05-2013, 12:02 PM
letsjet's Avatar
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
Does the 2011 Ram 1500 4.7L V8 have 8 plugs or 16?? If it's the same as my 2005 4.7 L V8 I know what I'm doing, but I read a post some where about upper and lower banks. Is it like the Hemi with 16 plugs to change? Any 2011 4.7L guys done a plug change and can answer, thanks.
Old 07-05-2013, 11:51 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
Its 8. There are 16 plugs on the hemi 5.7. Also the change interval is different between the two engines. 32,000 on hemi 5.7 and 48,000 on the 4.7.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 07-06-2013, 04:25 PM
letsjet's Avatar
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
Thanks United316, I was pretty sure it was only eight but I had read a thread where they were referring to the upper and lower banks. I did the plug change on my 2005 1500 4.7L and it was fairly simple. I know the newer 4.7L's have a decent horsepower increase over my 2005.
Old 07-23-2013, 09:49 PM
Walkercolt Walkercolt is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Trim Level: Big Horn Quad Cab
Color: Deep Cherry Red
Walkercolt is on a distinguished road
The heat shields are a pain, and some thick-wall sockets won't fit down in them.
Forgettabout the 48K plug changes. Your fuel economy will go to crap, especially if you run E-10 or if your's is a Flex-Fuel engine that can run E-15. Spark plugs aren't that expensive not to change then every 25K, IMHO. If you drive mainly in-town, think strongly about one heat-range hotter plugs. To check them, run thirty minutes at highway speed (on cruise) put it in neutral, shut the engine off and let it coast down, then pull a couple of plugs, one on each side (middle ones). If they're nice and light tan, you're perfect. If they're white, you need to go back to the OEM heat range. I have a 2004 Dakota with the early 4.7L and it has run rich since day one. I'm running Bosch single Platinums a heat range and a half hotter than the OEM Champions. After 20 minutes of the ECU "learning" what plugs were in it, I get better idle, better acceleration and a tiny bit better fuel economy, but there's nothing gonna make the early 4.7L get GOOD gas mileage.
Old 07-24-2013, 01:48 PM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Repacing sparkplugs
Judging from the way you asked your question, I'd just let the dealer do it. It's been many years since I've changed plugs myself and never owned a torque wrench. My opinion,...it's worth the extra cost to have your dealer do this for you. Think of it as a long term good investment.
Old 08-21-2013, 05:45 PM
Hogking Hogking is offline
Rep:103
Hogking will become famous soon enoughHogking will become famous soon enough
I agree...I can't be bothered. Piece of mind. Drop it off....couple hrs all done ready to roll. Doing it at home you could run in all sorts of trouble than your screwed. My dealer down the block is great bunch of guys.
Old 08-22-2013, 08:32 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The first gen 4.7L (2007 and older) has 8 spark plugs. The second gen 4.7L (2008 and newer) has 16 spark plugs. The 5.7L hemi also has 16 spark plugs.
Changing the plugs on the 08+ 4.7L isn't very hard, the only thing that's tricky is the upper bank plugs can get siezed to the coil boots and the boots rip. Then you have to fight to get the ripped boot out and then have to replace the coil at ~$20/ea as the boots aren't sold separately(although someone said NAPA now carries them but I didn't confirm).
If you're boots rip, take a piece of copper pipe(like for home plumbing), it's either 3/8" or 1/2", I don't recall off hand, and use it to push between the ripped boot and the plug. This will break the "seal", and then you can use needle nose pliers to pull the ripped boots out. This is typically only an issue if you go past the recommended maintenance interval.
08+ 4.7L uses different plugs on the upper and lower banks, make sure you get the correct plugs. Also it has different maintenance intervals for each 8.
Also forgot for the upper bank you need a thinwall spark plug socket else it won't fit. I had to take my thinwall socket and grind it down even thinner.
Sean
