Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-28-2012, 04:15 PM
Gibson3500 Gibson3500 is offline
Vehicle: 2005 Dodge ram 3500
Gibson3500 is on a distinguished road
Default 05 Ram 3500 Dulley shut off problem
Alright guys i am in desperate need of some help i was driving down the interstate today and got off the exit when i noticed my RPMs were dropping while i was giving it gas then it just shut off. it took about 3 tries to get it back started so i headed home and it happened again right after a stop light. I got off to a normal start and when i hit about 40 mph it bogged down again and shut off. i tried cranking it 3 times with no luck so i took the key out put it back in and it started right up. I have no clue what this could be all the gauges are perfect the fuel is good and no weird sounds. I hope somebody can shed some light on this situation this is my only means of transportation.
Thanks to everyone
Old 11-28-2012, 05:54 PM
dodge man's Avatar
dodge man dodge man is offline
Vehicle: 2004 Quad Cab diesel
Rep:221
dodge man has a spectacular aura aboutdodge man has a spectacular aura aboutdodge man has a spectacular aura about
Lift pump would be my first wild guess. When you turn the key on, but don't start the truck, you should be able to hear it running. You can also pull codes by doing the key truck, turn the key on and off, but don't start it, leaving the key on the last time, and the codes will show up in the odometer window.
2004 3/4 ton Quad Cab, 24 valve 5.9 Cummins
Old 11-29-2012, 07:41 AM
thanks man im gonna try that this morning and see what happens ill keep you guys posted thanks for the help
