Wheel offest - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-22-2012, 01:18 PM
Fresnoexpress Fresnoexpress is offline
Vehicle: 2012 Dodge Ram Regular Cab
Color: Mineral Gray
Fresnoexpress is on a distinguished road
Default Wheel offest
I'm looking online at purchasing a set of 22x9.5 Boss 338 wheels with 285/45-22 tires. they have an offset of +14mm. Is this the correct offset for my truck? Thanks in advance
Old 11-22-2012, 03:14 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
depends, are you running a lift? a level kit? if so what size and whos the manufacturer? most members on a stock truck will run between a -12mm or =0mm offset
hope this helps
Thanks
Jeremiah Hinkle
Discount Auto Performance
855-432-3278
sales@revelperformance.com
Old 11-22-2012, 04:52 PM
Color: Mineral Gray
My truck is 2wd, stock ride height. I do plan on lowering the rear 2" to level it out in the near future
Old 11-22-2012, 05:48 PM
Color: Mineral Gray
Oops, just realized i posted this on the lifted section. Could a mod please move this to the lowered section? thanks
Old 11-22-2012, 05:53 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
yea youll need a wheel spacer and lowering the truck those tires are gonna be really close to fitting, most put a level kit up front on there 4 wheel drives to get 35's to fit, you have 35.5's i would reccomend a smaller tire if your going to be dropping the truck, 2 wheel drives sit lower than 4 wheel drives, some 4x4's are able to get 35's to fit stock with the right offset wheel, however on a 4x2 i do not think this is going to be possible, so i would for sure level the front with the rear not the rear with the front, or get smaller tires and if you decide to level the front id run a 1.5" hub centric wheel spacer all the way around. This is just what i would do to insure proper fitment hopefully someone else chimes in to verify with me or has a better option for you.
Thanks
Jeremiah Hinkle
855-432-3278
Old 11-22-2012, 06:25 PM
Color: Mineral Gray
Unless my math is off a 285/45-22 is 32" tall and the stock size on the R/T, its actually an inch shorter than my stock 275/60-20's
Old 11-22-2012, 07:13 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
you are right my fault i thought he had said 325x45's so yes a 285x45 should be fine with no rubbing and if you drop the back these would work perfect, that is my fault, OP I apologize for the mis information.
Sorry
Jeremiah Hinkle
855-432-3278
