Old 11-22-2012, 12:31 PM
OMALLEY808 OMALLEY808 is offline
Vehicle: 2009 Dodge Ram SLT
Color: stone white
Rep:64
OMALLEY808 will become famous soon enough
Default Alignment HELP!
Anyone know what the specs should be for a 6" Rough country kit on a 2009 ram are?
Dealer just called and said the truck wouldnt line up to factory specs and asked if I had a spec with the kit??? ANYONE know??
Dealer is waiting for an answer...Can't get a hold of anyone at rough country...
Old 11-22-2012, 02:12 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
RCX is probably closed today, and as far as not lineing up with factory specs i am not sure to what this is supposed to mean, many many users are running a 6" RCX lift and have no issues at all, unless they are talking about factory wheels, in which case you do more often than not need to run a wheel spacer
hope this helps, maybe you can explain a little better what they mean by specs not lineing up and we can help you out better
Thanks
Jeremiah Hinkle
Discount Auto Performance
855-432-3278
Old 11-22-2012, 02:24 PM
Color: stone white
Rep:64
They are having trouble getting the alignment within the "factory" specs apparently. IE Caster, camber.
They said my truck would pull to the right and if I had any alignment specs for this kit to follow? I asked for exact numbers and which spec was out of wack so I should be getting a phone call back shortly with more info.
Old 11-22-2012, 03:48 PM
white4x4's Avatar
white4x4 white4x4 is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:80
white4x4 will become famous soon enough
just my .02 but if they are having problems aligning your truck they probaly shouldnt be doing it at all, i took my truck in the other day to get it aligned and i was in and out in less than an hour an my truck drives straight and doesnt pull at all, so i think you should maybe take it somewheres else cause they aint gonna be able to use " factory specs" with a 6'' lift but that just my .02 llet us know what they say when they call ya back
Old 11-22-2012, 03:58 PM
Color: stone white
Rep:64
These are the specs. Got the truck back and seems to drive half decent. Let me know if this looks normal to you guys...
Old 11-22-2012, 05:37 PM
09nitetrain 09nitetrain is offline
Vehicle: 2006 raqm 1500 trx4 hemi
Trim Level: trx4
Color: blue
Rep:20
09nitetrain is on a distinguished road
if caster was more than .5 you'll feel the slight drift
