Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Dodge Ram Decals
Old 11-23-2012, 09:07 AM
ACE778's Avatar
ACE778 ACE778 is offline
Vehicle: 2010 RAM 4X4
Trim Level: LARAMIE
ACE778 is on a distinguished road
Default Tie Rod End Issue
Hey guys, so have a question. In the spring I had moved and required to have an out of province inspection done... I was surprised when the shop told me that my drivers side outer tie rod end was worn and needed to be replaced in order to pass inspection. still under warranty only 40 000km approx at that point I had it replaced and all was good... now just a month ago I moved again and required another out of province inspection in a different province. only 15 000 km later approx and same issue drivers side outer tie rod end... of course no big deal still under warranty had it replaced and all good.
However my question is what is the underlying problem, what is causing this excessive wear? I would like to have the issue solved obviously before warranty runs out.
Any thoughts?
Old 04-20-2014, 10:12 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:763
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I know this is a necropost and you have likely resolved your issue, but since people read these threads to find answers if the same issue pops up in their truck I will go ahead and answer. This sounds like it may be an alignment issue.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
