Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 11-23-2012, 09:38 AM
bigtommy9285 bigtommy9285 is offline
Vehicle: 2006 Dodge Ram
bigtommy9285 is on a distinguished road
Exclamation 6th Gear
I just bought a used 06 Dodge Ram 1500 With a STD Trans. I noticed when i shift into 6th gear i loose speed even ehith the peddal to the floor. unless im goinbg 85 or better. What is 6th gear for if you have to be going 15-20 MPH over the limit to use it?
Old 11-25-2012, 09:03 PM
No Takers? .....................
Old 03-17-2013, 09:00 PM
RamBro1500's Avatar
RamBro1500 RamBro1500 is offline
Vehicle: 2008 Dodge Ram 1500
RamBro1500 is on a distinguished road
Default 6th Gear
I realize this is a late reply, but I am relatively new to the forum. I own a 2008 Ram SXT Regular Cab 6 speed manual. I regularly use 6th when I have reached a cruising speed anywhere from 55 and up. My truck will accelerate from 55 mph up in 6th, but if I want to pass, I will simply downshift to 5th or 4th. I use 6th basically as an overdrive to help with gas mileage. I could see where your truck might lose speed going up an incline, or maybe because it is heavier than mine (possibly a crew cab). I hope otherwise your Ram is serving you well (mine is.)
Old 03-18-2013, 07:39 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
You shouldnt have that severe of a loss of cruise in 6th. Obivously 6th is a cruising gear and you should have some accelleration availiable. I would look into why you have a loss of power....Do you have a pulsation or a miss while accelerating in 6th, or any gear? Might need a tune up......
speed, trans
