Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 11-23-2012, 11:20 AM
alorio1 alorio1 is offline
Vehicle: 1998 Dodge Ram 1500 SST
Trim Level: SST
alorio1 is on a distinguished road
Default Abs and brake light on issue fixed
My ABS and brake light stated coming on 3 weeks ago. I read up on all the possibilties that would cause this problem which was speed sensor in the differental, so I replaced it but the ABS and brake light still came on and I had no cruise control either. I replaced the pump and module over the left fender with no success. A friend of mine said his buddy who runs a small shop for auto repairs just got a new Snapon scanner that read everything on a car or truck and he was intrested in helping me trouble shoot the ABS problem wanting to check his scanner out also. The scanner read 3 codes which I probably set off when replacing the pump and bleeding the brake system. After the codes were cleared I test drove the truck and same thing happened. He then scanned the ABS system again and it said BRAKE LIGHT SWITCH CLOSED. We pressed the brakes and the brake lights were working just fine. Then we inspected the wires going to brake light switch and everything was in order. We then decided to replace the switch any way. Upon removal of the switch the was a 6 wire plug to the switch. After removing the switch the plunger was stiff and barely moved as if the sping was boken internally. We replaced the switch and cleared the code one again and now my ABS light problem has gone. Who would have ever thought a brake light switch would have caused this problem ?
Old 11-23-2012, 12:22 PM
Resident Technician
Rep:1909
I would - but I've been in the repair business nearly 20 years...
Old 04-09-2013, 03:34 PM
pen101 pen101 is offline
Vehicle: 2004 doge ram 1500 4x4
Trim Level: Base
Color: Blue
pen101 is on a distinguished road
If anybody watching this post....
Take truck off road for winter, "just winter beat it" left cab light on last month and battery went dead, recharged battery and on the "blindside" of the tray was a two bolt 1" square aftermarket thingy (I believe this to be part of the trailer package) I noticed after hitting it that I was not the first to hit (band-aided with silicone) it, but the "bi-metal" thingy underneath came flying out.
Turn my key to the on position and my speedo goes between 35-40kmh, and my abs and brakelight are both on.
No codes, slipt her out for a quick ten minute jog on the highway, speedo works fine but those two lights did not go out neither did any codes come up.(my cheepo code reader says computer yet to set?)
I'll throw a sticker on her and take her for another spin before I take the 55.00 out of pocket for the rear diff speed sensor which is my question...is there anyway to test this unit...by Ohms or voltage?
