Old 11-23-2012, 08:56 PM
jvans007 jvans007 is offline
Vehicle: 2008 Dodge Ram
Trim Level: 1500 2WD Crew Cab
Color: Blue
jvans007 is on a distinguished road
Default brakes, abs, engine & no speedo
my brake, ABS, engine lights stay on and the speed odometer stop working. I took it to the dealership and they put a scanner on it and 3 errors came up but with no codes. I have replaced the "rear speed sensor" and today I replace the front Hub with speed sensor on it. The lights are still on and the speedo still doesn't work. the battery was disconnected for a 24 hr. period and I tried the instrument cluster reset and after it went through its diagnostics it said "hr 2205" what ever that means, and I am still having the above problems. I am at my wits end. Can any one help me here, because I can't get any information from the dealership, infact they want to keep the truck for 4-5 days. Help Please
Old 11-23-2012, 09:08 PM
Rep:1845
Three errors with no codes? I'd like to know what they mean by that for starters.
Old 11-24-2012, 11:28 AM
Color: Blue
That's just it..the errors that were brought out said unidintifyable
Old 11-24-2012, 11:37 PM
Color: Blue
okey, I went back through to verify every step was correct. No change, so I had a new scan made and this time I receive 3 u-codes: u0121, u1120 and u1110. Looked up definitions but I'm still at a loss.
Old 03-09-2013, 08:41 PM
gary333 gary333 is offline
Vehicle: 2002 dodge ram
gary333 is on a distinguished road
I just had the exact same problem,except I also had no reverse lights also.what My mechanic found was a bad wire(corroted(man I can't spell)) under the fuse box.It was a brown wire in one of the big clips that hook to the fuse pannel(toward the front of the truck).he found it AFTER he took all the tape off around the clip the wire then fell out of the clip.It was corroted at the terminal
