alignment and ball joints - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-24-2012, 03:23 AM
Drum4the1's Avatar
Drum4the1 Drum4the1 is offline
Vehicle: 2006 dodge ram 1500
Rep:35
Drum4the1 is on a distinguished road
Default alignment and ball joints
2006 Ram 1500 4.7, 4 door, 4x4, 35,000 miles. Took it in for an alignment and was told that the left upper ball joint is loose. They wanted to only replace the upper. Shouldn't both upper and lower be replaced? That's always been my practice but I haven't owned a truck with so low miles before. Is it possible that the lower will still be ok because there's only 35,000 miles on it?
Old 11-24-2012, 10:08 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
I personally would not change the lower especially with those kind of miles.
I would however go ahead and change the other upper ball joint (make sure you get ones with grease fittings)
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 11-25-2012, 12:32 PM
Drum4the1's Avatar
Rep:35
That's what I was thinking but I thought I'd ask around. Thanks.
Old 11-25-2012, 01:10 PM
Resident Technician
Rep:1915
I would replace both and here's why: Dodge ball joints are notorious for failure, as evidenced by your upper already going bad. Since this repair is coming our of your pocket you can save yourself a future labor expense by doing both now. If you do one now and the lower fails in 6 months, you'll feel foolish and your wallet will feel lighter. I would insist on good aftermarket parts like Moog or the high line Napa joints.
Old 11-26-2012, 01:48 AM
Drum4the1's Avatar
Rep:35
Ok. It's only an extra $25 for the lower. Thanks.
