Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 11-24-2012, 06:02 AM
cille cille is offline
Vehicle: 2005 Dodge Ram
cille is on a distinguished road
Default No Power to the Fuel Pump =(
2005 Dodge Ram will not turn over. Everything inside turns on.. looks like there is no power going to the fuel pump. Checked the fuses, still stumped. HELP. I MISS MY BABY!!!!
Old 11-25-2012, 11:58 AM
RamTech RamTech is online now
Rep:1845
How are you checking power to the pump? Are you using a test light or meter at the pump connector? Have you the checked the ground at the pump and the pump relay for proper operation?
Old 11-27-2012, 08:19 PM
Default No power to fuel pump
Used a meter to test the power going into the pump. NOTHING. Fuses, relays are fine..
Old 11-28-2012, 07:44 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2010 Dodge ram
Rep:81
does the truck want to start but just isn't getting gas or is nothing happening? If nothing is happening when you turn the key it probably is the crank shaft position sensor. I had one go in a grand cherokee that I owned. 500 bucks later in labor chasing wires, new computer, and everything in between and it was a $50 sensor
2010 Ram 2500 SLT 6.7L Cummins, S&B CAI, H&S Mini Maxx Race Tuner, DPF Delete, EGR Delete, Bilstein 5100's, raceland 4" e-cutout
Old 11-28-2012, 09:59 AM
Rep:1845
If you're positive the pump relay is working properly and there is 12V on the 30 terminal then there is a break in the wire going to the pump from the relay. With that being said, I have to tell you I've never seen that happen in nearly 20 years in the business. May I ask how you checked the relays?
Old 08-19-2013, 11:21 AM
jerryhall jerryhall is offline
Vehicle: 2004 Dodge Ram
Color: Blue
jerryhall is on a distinguished road
I am new to this so Im sure if this will be seen. I have the same type problem. 2004 5.9 went dead like the key was shut off. started one time for a few seconds then dead for good. I changed the fuel pump (intank) has been converted. Still nothing. The pump isn't running. Help!!
