Old 11-24-2012, 11:41 AM
alkells alkells is offline
Vehicle: Dodge Ram 2005
Trim Level: standard
alkells is on a distinguished road
Default Electgrical Problem remote lock & Unlock
My remote lock and unlock no longer operates. If I insert the key and turn on the ignition the remote will then function OK? The radio and the interior lights have also stopped working. I think it is all part of the same problem. I have checked all the fuses, changed the battery in the remote and changed out the radio, however the problem persists??
Anyone have any ideas.
Thanks Al
Old 12-03-2012, 01:19 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I assume you mean that the radio and interior lights only work with the ignition on as well? Sounds like you have lost your live feed from the battery for these accessories. Whether it's due to a fuse or a corroded/disconnected wire is what you need to figure out.
Maybe check here for your wiring diagram -> http://www.rambodybuilder.com/2005sbbgl/dr/drmo.pdf
Old 12-03-2012, 01:53 PM
Rep:1885
The instrument cluster is the major component that controls interior lighting and door lock actuator operation. Clusters are known to fail and this would be my first guess.
