Battery issues and i think radio is to blame - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-26-2012, 06:43 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Default Battery issues and i think radio is to blame
Let me start off with i have installed an aftermarket kenwood deck. I wired every thing to the harness correctly but over the last year or so ive had some issues. It would some times come on with ignition and sometimes not. I did a battery pull reset and magically its started coming on and off with ignition again. However i dont think it was shutting off completely because since temperatures have gotten cooler i have had some issues in the morning with the truck starting. So i disconnected the battery charged it up sunday and also reinstalled it sunday opened my cab this am to find the deck had come on and been in standby mode all night. The truck was basically dead it managed to start so i let it run then drove to work. I manually shut the power off to the deck and left it that way all day. And the truck started fine after work. The real test is going to be letting it sit the night and see how it starts tomrorw. I have it wired correctly and i have checked that the last time it acted up. This one is really throwing me off because i know it only needs a small constant power for the clock....possible a short somewhere.
Old 11-26-2012, 07:40 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
What type of harness are you using and has the harness been checked to make sure that the wiring was correct and that nothing came loose or was pinched during installation? It could be an accessory signal issue that sends power to the radio when it shouldn't be. Aside from troubleshooting the wiring, the next step would be to check the receiver for a problem.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 11-28-2012, 09:19 AM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Default Check
Yeah, I would pull put the whole radio. Check all wires, both harnesses and even check the power and the ground running to the radio. Basically a run through of everything.
Green Interior LEDs
