Old 12-24-2012, 09:26 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
I was lucky enough to find a '13 equipped with the controller, and it's awesome. It's built into the EVIC 7' display, so when you adjust your gain or slide the manual control, it shows all the details on the EVIC. Very nicely integrated
Old 01-14-2013, 06:47 PM
billsfan69 billsfan69 is offline
Vehicle: 2013 Ram Laramie Crew Cab
Trim Level: Laramie Crew
billsfan69 is on a distinguished road
MunchRam...I am picking up the 2 part numbers you provided tomorrow. Have you found out anything further on this????
Old 01-14-2013, 07:54 PM
Kman521 Kman521 is offline
Vehicle: 2013 Dodge Ram
Kman521 is on a distinguished road
Originally Posted by MunchRAM View Post
Part number is 68105206AB for the switch and 68092732AC for the module.
I'm not sure if it is a plug and play, or if the wiring harness is required as I'm still looking into this as well.
Just curious how you came across these part numbers?
I called the dealer today with these numbers and the switch number came up but the controller number came up for a different year. I was told to call back in a couple of months because nothing is available for the 2013 yet.
If it's not available wht happens if the factory one develops a problem?
The dealer did confirm by the VIN that my truck does have the wiring and I do see the two connectors under the dash just left of the center dash.
Thanks,
Keith
Old 01-14-2013, 09:16 PM
Parker420 Parker420 is offline
Vehicle: 2013 Dodge Ram Laramie
Parker420 is on a distinguished road
The part number for the intergrated controller is 82213474 .... however, not available yet
Old 01-14-2013, 09:35 PM
sorry....just found out this is not correct
Old 01-14-2013, 11:00 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
Parts are not available for sale as of Yet but can be REPLACED under warranty. Parts will be available for sale sometime in March. A dealer can get the part # if they really wanted (using a warranty replacment order) however it would be no good as it wouldn't be able to be ordered for retail sale.
Old 01-16-2013, 07:31 PM
Problem Solved......MunchRam was right on the money. Had the module and switch installed today. Module goes behind the kick panel below the steering column. They zip tied my module in for now as I didn't order the bracket ($1.50) that mounts to dash assembly. Switch was simply removing the blank and installing switch. All wiring is already in the vehicle. Once installed, the dealer will have to add the feature to the "dealer installed options" in dealer connect then the tech must restore configuration to the vehicles computers. The whole process took about 1hr 15 mins. FWIW: truck has trailer tow package from the factory. Hit me up if you need more info....
Old 01-16-2013, 07:37 PM
Parts are available.....waited a few extra days but don't let them tell you they are only for warranty. You didn't spend that kind of money to be waiting. If they really want to increase their CSI scores they will special handle the parts and I am sure you will give them a good survey for their efforts.
Old 01-16-2013, 09:48 PM
Just curious how much they charged and was this written into the sales deal or an after thought?
I bought my truck from a dealer 1.5 hours away from where I live because the local dealer wouldn't give me the same deal. I don't think the local dealer wants to help me too much so I don't think they care about their CSI.
The parts person told me they aren't available so maybe I have to go and complain a little more.
Old 01-17-2013, 07:29 AM
Rep:71
Like I said parts for 2013's are not available for sale yet. however it doesn't mean a hungry dealership won't go above and beyond to make a sale and/or keep a customer happy. Like the saying goes " There's more then one way to skin a cat" specially when your hungry
If your dealer isn't hungry to keep you happy push little harder or go to another dealer who is hungry to get you what you want.
