coolant leak 2000 5.2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-26-2012, 08:17 PM
farleyd farleyd is offline
Vehicle: 2000 Dodge Ram 1500
farleyd is on a distinguished road
Default coolant leak 2000 5.2
I have a leak coming between the bell housing and engine block on the drivers side. I did a search and got a general idea off what might be wrong. does anyone have a link showing freez plug locations. any thoughts or ideas would help. This is my first time with a dodge of any kind. thanks!!!
Old 11-27-2012, 05:04 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
The only way to access the two freeze plugs between the transmission and block is to remove the transmission. This usually happens after a long time, when you do remove the freeze plugs be sure to clean the block out, you will find some of the original casting sand in the block still...
I remember when I rebuilt my transmission, I inspected those plugs and no leaks... Then I but the transmission in and a few days later... Drip drip drip drip... Had to remove the transmission again to replace no more than 3 bucks worth of freeze plugs, but it was good because I found that the torque converter bolts came loose and that is when I learned that locktite always on converter bolts, but it gave me the opportunity to replace the rear planet that I chewed up. So it wasn't all that bad, just...
Anyways, have fun!
