Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 11-27-2012, 11:31 AM
Resident Technician
Rep:1915
Default A Tale Of Two Tensioners (Catastrophic Failure Update)
In light of the tensioner failures in Hemi engines, I decided to check the tensioner differences in the newer and engines. Here's what I've found.
All Hemi engines (6.1L included) installed through 2008 have the older leaf spring style tensioner which is NOT prone to this failure, so you guys and gals can relax.
In 2009, with the introduction of the Eagle engine, the new style coil spring tensioner was also introduced into the 5.7 Hemi in all applications. In 2011, a running change was made to the tensioner (from PN 53022115AG to PN 53022115AH) so this year could have either part number installed. 2012 and up has the latest revision installed. This information also applies to the 6.4 Hemi.
DISCLAIMER - The following paragraph is not information from Chrysler. It is my own opinion based on information I have gathered from various sources.
From what I am seeing, I believe the AG part number is the one causing the problem. This would explain the running change in 2011 as well as the mileages of known failures. That means that the 2009-2010 models as well as some 2011 could be affected.
For those of you that are curious, here are images of the coil spring and leaf spring styles. Both coil spring part numbers appear to be the same in all images I have seen thus far.
Coil Spring Style
The timing chain tensioner is a spring loaded design. It consists of two chain guide shoes. One shoe is fixed in place and the other is spring loaded to keep tension on the chain.
Leaf Spring Style
The timing chain tension is maintained by routing the timing chain through the tensioner assembly. A nylon covered spring steel arm presses on the timing chain maintaining the correct chain tension.
Old 11-27-2012, 11:48 AM
SFVDOC's Avatar
SFVDOC SFVDOC is offline
Vehicle: 2012 Ram 1500 CC 4X4
Rep:83
SFVDOC will become famous soon enough
So other than having model year 20XX is there any other way of knowing which tensioner you have?
I have a 2012 so I guess i am ok???
Old 11-27-2012, 11:51 AM
Resident Technician
Rep:1915
No, the only way to be sure, if you have a 2011, would be to disassemble the front of the engine. If my suspicions are correct, yours should be ok.
Old 11-27-2012, 12:05 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Thanks for sharing RamTech, much appreciated.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 11-27-2012, 01:36 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
Thank you very much for the info. I am sure that the 4th gen members here will really appreciate this!
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 11-27-2012, 03:46 PM
acs0424's Avatar
acs0424 acs0424 is offline
Vehicle: 2007 Dodge Ram 1500
Rep:15
acs0424 is on a distinguished road
Thanks for the info. I'd been following the thread and it's good to know some 2011's may be affected. I'll have to let my mom know to watch out for it on her Jeep GC.
Old 11-27-2012, 04:02 PM
61Dodge 61Dodge is offline
Vehicle: 2013 Ram 1500 RCLB 4x4 3.92 Ls
Trim Level: Tradesman
Color: Mineral Gray Metalic
Rep:23
61Dodge is on a distinguished road
Thanks my 2013 should be ok.
Wife's ride 2004 Black Durango 4.7
Oldest Dodge 61 Baby Blue D100 slant 6 with 3 on the tree
Old 11-27-2012, 05:18 PM
walc's Avatar
walc walc is offline
Vehicle: 2016 Ram Power Wagon SLT
Trim Level: Power Wagon SLT
Color: Blue
walc is on a distinguished road
RamTech,
Thanks very much for taking the time to research and keep us informed.
Rep points added.
2016 Power Wagon SLT
Old 11-27-2012, 11:11 PM
Rep:4253
I second that ^^^^ and even though this does not apply to me, good info, we appreciate the research and you posting your findings.
Old 11-27-2012, 11:18 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:778
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
another thak you ram tech. let me ask, what mileage are on the trucks when the "failure" occurs.
