Question for all RAM Techs?????? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Old 11-28-2012, 02:47 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:86
jmr will become famous soon enough
Default Question for all RAM Techs??????
My truck is a '12 Express with the E brake option and the EVIC dash. I added the overhead console and installed the Compass/Homelink module. The homelink works great and it displays the Transmitting messages in the EVIC.
I want to enable the Compass and so I had my dealer add sales code JFJ (Temperature And Compass Gauge) to the trucks configuration.
The dealer could not do it saying it was not a dealer add on option to select.
So my question is how can I enable the Compass to display in the EVIC?
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 11-28-2012, 03:24 PM
Resident Technician
Rep:1915
Good question. I've never seen it tried.
Old 11-28-2012, 03:52 PM
JimsRamTruck2012's Avatar
Vehicle: 2012 Ram Express
Trim Level: Express Package
Color: Mineral Gray Matalic
Rep:327
There is only 1 way I can think of to get it to work, and that is replace the PCM with one that has the option programmed into it. (Not Cheap. I can tell you that.) And it may effect the transmission's shift points.
It seems the Ram division as well as the others programmed these PCMs so you can't alter them at all.
Old 11-28-2012, 05:01 PM
Resident Technician
Rep:1915
Changing the PCM will lighten your wallet but it won't change your shift points. It won't produce the result you're looking for either.
I've done some research and haven't come up with much. It seems to me that the compass should have started displaying once the option code was entered by the dealer and the tech did a configuration restoration. Come to think of it, a tech DID do a reconfiguration, right?
Old 11-28-2012, 05:15 PM
jmr's Avatar
jmr jmr is offline
Rep:86
They showed me a webpage and entered in my VIN which brought up all my current options. They said under dealer installed options the JFJ sales code was not displaying to be selected. Are they in the wrong screen?
How would you go about entering the sales code so that it will be added to my trucks configuration?
Rep:2929
I am just guessing, but ...
if you could find an EXPRESS that was ordered with the INTEGRATED BRAKE CONTROLLER, if you had that vehicles VIN #, the tech may be able to enter that vehicles VIN# & bring up the codes & punch those same codes into your Express to make everything work ????
Old 11-28-2012, 05:37 PM
jmr's Avatar
jmr jmr is offline
Rep:86
It would have to be something like a SLT or Big Horn since they came standard with the overhead console and compass. My Express has the trailer brake option and EVIC dash but no compass because they don't have a overhead console in any Express model.
Do you think I should have them try one of their trucks on the lot to get the proper option code?
Old 11-28-2012, 05:50 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
Gt is right, halfway. you got the other half. you need a vin from a same year SLTor higher.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 11-28-2012, 06:29 PM
jmr's Avatar
jmr jmr is offline
Rep:86
I just went by the dealers and had them lookup a '12 BigHorn on their lot with the compass and temperature gauge and the option code is JFJS. So I made another appointment for this Friday to try it again since the service manager and one other person can add option codes.
Is there a screen where they plug in the 4 character sales code when updating the configuration?
Old 11-28-2012, 07:09 PM
Resident Technician
Rep:1915
JMR, here's how it's supposed to work.
Step 1 -Someone, be it a manager, advisor or technician will enter the option code into a PC.
Step 2 - A technician then connects the wiTECH scan tool to the vehicle, downloads the new configuration and then updates the TIPM with the new information via the restore vehicle configuration function.
The new option is now ready for use. Sometimes installed options will partially work without the reconfiguration being performed, so this could explain your situation. If they didn't do both of the above steps, they did NOT do it right.
