Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 11-28-2012, 03:37 PM
08JD 08JD is offline
Vehicle: 2002 dodge ram
08JD is on a distinguished road
Default 2002 Dodge Ram 3.7 Rough Idle/stalling out.
So question for you guys, or if anyone can point me in the right direction with a member who might know.
2002 dodge ram 3.7l v6 - 5speed with 148,000 miles on it.
When at a stop light, sometimes it will do it, sometimes it wont, or sometimes it will do it everytime. it will have a lower rpm idle and really idle rough. Than it will eventually stall. If i catch it before it stalls out and start driving away, i notice that when shifting from 1st gear into 2nd (with the cluch in, the rpms will continue to rise until around 3k). when stalling out it spudders and makes a knock sound.
weird huh?
Only code that im pulling is p0442, evaporative emission control system leak detected (small leak).
I have a gas cap ordered, its on its way. Also i climbed underneath the truck and checked the hoses around it, noticed that zip ties are securing them to the nipple. (stupid previous owner, im going to go ahead and do it the right way).
Now my question is, if its just the gas cap (since it doesn't seem to seal tight), would this really be causing this issue to happen with my motor?
Motor sounds great when running great, normal injector ticking, nothing else.
Please get back to me,
John
Old 11-28-2012, 03:48 PM
Rep:1884
The EVAP code has nothing to do with your problems. Look for a dirty throttle body and IAC motor as the source of your stalling problem and worn out spark plugs and/or carbon buildup on the intake valves for the rough running.
Old 11-28-2012, 03:52 PM
I just talked to my fiances father who was a mechanic for a while now and he said on his 2003 gmc sierra he had similar issues and complaints because of the gas cap not sealing properly.
just curious if its the same with my ram.
Old 11-28-2012, 06:59 PM
HemiLonestar's Avatar
Rep:274
Loose gas cap may give you a code, it will NOT however cause your engine to run like shit.
"Big Red"
2006 Charger R/T
Old 11-28-2012, 09:15 PM
***Update***
i decided to pull the battery off, let the truck sit for around 15 min. and reconnected it. Check engine light turned off for the evap canister leak. Hasn't came back on yet, most likely will.
But i did manage to catch a new code while it was beginning to stall out p0031 H02S Heater Control Circuit Low Bank 1 Sensor 1.
Im assuming o2 sensor, but its funny since i just changed that o2 sensor for a different code and has been fine for around 200 miles.
Faulty o2 sensor? but it ran fine with a faulty o2 sensor before...
Any advice, let me know, please.
Old 11-28-2012, 09:18 PM
if it helps, o2 sensor was bought from discount auto parts, am i better off getting mopar genuine parts? or rock auto? etc.
Looking to not hurt my engine, i still am getting good gas mileage but power sucks when trying to accelerate from a stop with a engine about to stall
Old 02-22-2014, 03:53 PM
Dorian1979 Dorian1979 is offline
Vehicle: 2002 Dodge Ram 1500 5.9L
Trim Level: SLT Sport
Dorian1979 is on a distinguished road
weird huh?
John
Hi, did you ever find out what was causing the rough idle and stalling out?
I have an 02 5.9 ram 1500. It is doing the same thing. Only has stalled a few times. But rough idles with the rpms going very low.. When I catch it before stall it feels like it's going to stall out with the knocking sound. I just changed the tps today, hoping that's it. But want edit I see if you ever pinpointed the issue. Thanks!
Old 06-04-2014, 01:22 PM
boyohboy's Avatar
boyohboy boyohboy is offline
Vehicle: 2008 Dodge Ram
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
boyohboy is on a distinguished road
I had a Town and Country Van that began doing that and eventually would just stop running while driving. I don't remember any codes as this happened a long time ago. But eventually it turned out to be a problem with the electronic ignition system over-heating and cutting out. The other issue I had was with a throttle body wearing out causing a rich fuel problem. Lou.
