Old 11-28-2012, 04:09 PM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
Default Is a 1.75" Rear Coil Spacer too much???
I am putting the Bilstein 5100's on all 4 corners @ 2.8", 1.25" Body Lift, and ordered a 1.75" rear coil spacer...The more I think about it is that going to be too much? I am wanting more of a leveled look but want the rear higher for load purposes although for the majority of the time there won't be a load...What do ya'll think???
Old 11-28-2012, 06:54 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
if you go 2.1 you will be pretty close to level, depending on your factory rake of 2.5-3.5", if you go 2.8 you might be a little nose high in which case i would suggest a 3/4" spacer, if you are on the lower side that is, if you are on the higher side i would not recommend a rear spacer as you will not look level at all and possibly even worse than stock, i am not familiar with a 1.75 rear coil spacer, but i do know they manufacture 3/4", 1", and 1.5" in my build log i have a lift with 2.75" procomp shocks in the front and a 1.5" spacer if you check it out that would give you an idea of what you would likely look like at 2.1 with a 3" factory rake as i have almost exactly a 1" rake on my truck, however dont look at how tall the truck is just at the rake as you can not achieve my height with just adjustable shocks, and make sure when you order your shock you get the proper ones for the rear as they are not the same as the front
We have a shock upgrade kit onsale right now for all 4 corners of your truck check it out, best prices available
http://discountautoperformance.com/s...roducts_id=131
Hope this info helps, let us know what you end up going and show us some pics too we love to see everyones trucks and mods
thanks
Jeremiah Hinkle
Discount Auto Performance
855-432-3278
Old 11-29-2012, 08:23 AM
Rep:108
thanks
Jeremiah Hinkle
855-432-3278
Thanks, but I ordered all 4 last week from Allshocks.com for $355 shipped to my door. Thinking I might order a 3/4" or 1" spacer and return the 1.75"... I guess we will see how it looks...
Old 11-29-2012, 10:07 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
With the 1.75 you will likely still have a "factory" looking rake.
Old 11-29-2012, 05:03 PM
There is a problem I see here.....
You will not be able to use that rear coil spacer on the rear 5100's as it will extend the travel of the shock and it will not react or feel the same.
The max you can put in with the 5100 rear is 1" rear coil spacer.
This is not a problem. A) return it and continue to use your stock shock B) exchange it for a 5125 that has a longer travel to support the addition 3/4". I would get one that allows for 2" addition.
Bilsteins at 2.8 on a stock truck will level your truck out. You may find it too level and may appear at times as nose high.
Average rake on our rams is 2.75".
With the 1.75" rear coil spacer you will have 1.5-1.75" rake yet again. 1" less than stock, but still a rake.
Not bad, if you like that.....
But if you want to eliminate the rake but have some and use the 5100 in the rear, get a 1". you will more than likely have 3/4" rake which to me is perfect and it will allow you to haul some weight in the rear without it looking like a cali lean.....LOL
My take and IMO - return/exchange that rear coil spacer for 1" or 1.25" if you want 1" of rake, but 1" is perfect and run everything you have.
Want to see a member with this exact setup?
Look up Bocephus. He has maxed Bilsteins, 1.25" body lift and 1" rear coil spacer with the 5100 in the rear as well.
I also think Newfiebullet also has something similar, so look him up as well
Great looking lift if you ask me
Old 11-29-2012, 09:15 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
You'll just have quite a bit of rake. If you run a rear spacer I'd do a 1". BTW those rear bilstien shocks will be fine with the 1.75"spacer. They allow up to an inch of rear lift bc their an inch longer than the stockers....
[CENTER][SIGPIC][/SIGPIC]
Old 11-29-2012, 09:55 PM
Candy, good info on the rear 5100's
Old 11-29-2012, 10:03 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
i agree with Andrew, and candy you are correct on the 5100's. I personally would do a 5125 with 12" or 14" of travel OP if you are considering this all can be found in our store at discountautoperformance.com/store
Any other questions let us know !
Thanks
Jeremiah
855-432-3278
Old 11-29-2012, 10:26 PM
candy08's Avatar
Rep:213
Those 5100s are 10" travel at 16 collapsed to 26 extended.....thats only 2-2.5" shorter than the 6" lift rcx shocks
If he went to 12"-14", I'd suggest limiting straps or coil retainers. Losing a coil on a trail would be a pita......but too much flex is way better then not enough flex
Old 11-29-2012, 10:41 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
This is true, it would be a pita but like you say more is better than not enough
