air bags - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-28-2012, 10:04 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
Default air bags
need some opinions, if you have air bags... i wanna know how well they work for the sag in your truck... are they worth the money??
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 11-29-2012, 03:49 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Why is your truck saging? Is it because you have a load in the bed or are the springs worn out?
If it's to level the load then yes they help out greatly. I have used them on several vehicles in the past and they are on my list for my current truck. They will add stability while towing/hauling and keep the truck level so your headlights are aimed properly (they arn't very helpfull if they are aimed up at the sky when you are driving at night).
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 11-29-2012, 04:18 AM
aderschon's Avatar
aderschon aderschon is offline
Vehicle: 2012 ram 1500
aderschon is on a distinguished road
I have the Air Lift brand bags I bought from suspension connection.com for less than $100. I read reviews on both air lift and Firestone bags and these seemed like the better choice. Easy install and they work awesome. I pull a 26' cabin cruiser boat and a 20x8.5 enclosed car hauler with no sag at all. Here is a pic with the car trailer. My truck also has a 6" pro comp lift. Good luck.
Old 11-29-2012, 08:01 AM
chadster21's Avatar
Rep:108
looks pretty good... i just want them for when i have my quad in the back or towing etc. was the install hard?
Old 11-29-2012, 09:31 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
Easy install took about 45 mins and work great..
Old 11-29-2012, 06:16 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
chad, because you got a lift, the airlift will keep the coils that is compressed from sagging.
but the coils that the airbag doesn't reach will sag, but it is few coils.
Given you will have a 1.75" rear coil spacer and if you sag another 1/4" with the airbags in, you will still sit level.
And, yes....the airlift 1000 does work on a lifted truck
sales@revelperformance.com
Old 11-29-2012, 06:30 PM
aderschon's Avatar
Install was very easy. I dropped the spare tire to make more room to work and ran the filler valve stem right next to the hitch. There are 2 holes already drilled on my factory receiver hitch so I just used that. I run about 5lbs in them when not towing/hauling and pump them up to 30lbs when towing.
**tip, I stuck my hi-lift jack in the receiver hitch and jacked up the suspension so the coils were stretched all the way to make it easier to put the bags in the coils.
Old 11-29-2012, 06:59 PM
Revel Performance
Rep:1804
Hi-lift jack??
I want to make my install easy as well. Lol
Old 11-29-2012, 09:12 PM
chadster21's Avatar
Rep:108
i think i will be pickin these up.. i hate when my truck sags
Old 11-29-2012, 09:17 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
Hi Lift jack, very handy.
