Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 01-19-2013, 06:15 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Apologize!! Got the Month year mixed up. Build /manufacture date is December 2010. I have the RHB unit and yes it is factory installed.
Old 01-21-2013, 03:16 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Ok, would you mind trying something for me?
I would like you to download the file mentioned in the 1st posting in this thread.
After you DL it, put it on your thumb drive, then. copy it again so that you have 2 files on the thumb drive:
uconnect.upd
uconnect.upn
Now rename the 2nd file to .upn so that the files look like:
uconnect.upd
uconnect.upn
Please try the thumb drive in the vehicle again. After we get this update to take, then you'll want to do the 2nd update for the streaming audio sound quality that I have at the bottom of the 1st post in this thread.
Old 05-23-2013, 11:16 PM
Munki63 Munki63 is offline
Vehicle: 2011 Ram
Munki63 is on a distinguished road
I just used a mac, Only problem I had is I accidentally downloaded the file twice, the unit wont recognize the file unless its uconnect.upd, so the second file I used was labeled uconnect-1.upd and it wouldnt work
Old 05-24-2013, 09:52 AM
Rep:73
So, you it updated ok?
Old 05-25-2013, 01:27 PM
Vehicle: 2011 Ram
ya, once I changed the file name everything worked great
Thanks
Are there any new updates?
Old 05-29-2013, 02:13 PM
Rep:73
No, I haven't heard about any new updates yet. If I remember correctly, the 2011 Uconnect module is tapped out because of the available memory space. Very little left.
Thanks
Old 08-03-2013, 03:37 PM
Texas Ram 1472 Texas Ram 1472 is offline
Vehicle: 2013 Dodge Ram 1500 4x4
Trim Level: Lone Star
Color: Deep Cherry Pearl
Texas Ram 1472 is on a distinguished road
Hey guys,
I seem to be having the same issue with my 2013 Dodge that has Uconnect. It keeps flashing on my screen "please insert update USB" and I also took it to the dealer and they were of no help an said that its a wiring issue. I was wondering if anyone could help me with getting the update downloaded? Any help would be greatly appreciated!
Thanks,
Chad
Old 08-05-2013, 11:08 AM
Rep:73
There are 3 different suppliers for the uconnect system. This particular update is not for the 2013 Uconnect system in your truck.
Unfortunately, it doesn't appear that Dodge get a very good job at Validating this system before releasing it to be built into the vehicles.
Originally Posted by Texas Ram 1472 View Post
Hey guys,
Thanks,
Chad
Old 08-05-2013, 09:47 PM
ksc8850's Avatar
ksc8850 ksc8850 is offline
Vehicle: 2011 Ram 3500
Color: Gray
ksc8850 is on a distinguished road
Default 201 RHB Update
There's not been an update since? My GPS told me it was over a year old and to get an update...the speed limits have increased here in Ohio...incredible!
KSC8850 - 2011 Ram 3500 Crew Cab Dually, Torklift Truck Camper Tiedown System & Stable Loads
Old 08-06-2013, 12:33 PM
Rep:73
ok, just to clear up a little confusion. With the RES, REQ, RBZ & RHB radios, there is an external Uconnect module. The radio and Uconnect each have separate SW updates. This particular update is for the Uconnect module and has nothing to do with the radio. There are newer SW versions for the radio depending on which version that you currently have on the radio. Can you tell me which version you have now?
