Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 02-07-2013, 10:12 AM
gunfighter's Avatar
gunfighter gunfighter is offline
Vehicle: 2001 Ram 2500
gunfighter is on a distinguished road
Mine was acting funky for awhile, similar problem, Would run ok most of the time and then out of the blue would just fall on it's face. Had to pull the cats, one went bad. FTR without the cats the truck runs like a scalded ape, it'll eat 35" tires without issue now, could never do that before. My culprit was the spark plugs, worn out, not gapped properly, once I changed them out it never did it again, about 1500 miles so far.
Old 03-24-2013, 12:16 AM
Big Bob Big Bob is offline
Vehicle: 1995 Dodge Ram 2500
Trim Level: SLT Laramie
Big Bob is on a distinguished road
Ok, after a couple of months screwing around with this, I have finally fixed the problem. It was just two weeks ago when I put two and two together and had a brainstorm that may or may not have worked.
Essentially all operating parameters are pre-determined until the engine is warmed to normal operating temp. At that point the PCM takes over, this may be over simplified, but this is how I understand it.
My engine ran fine until it got to normal operating temp, hence the PCM was running the show, something must be wrong the PCM. I found a used one in Montana for $125.00, bought it and had it shipped to me. It took about 5 minutes to swap out with the old one, with one small back fire the engine fired up, and is now running fine. I did have a 13 code (MAP sensor), I took that out, cleaned it up and the code is now gone.
However (it seems there is always a however) my maintenance required light is on, I have no idea why. The only code I get is 12, because I had the battery disconnected to try and clear the 13 after I cleaned it.
Does anybody have any ideas as to what the light represents or how to get rid of it. It is not reassuring while I'm driving.
Old 03-27-2013, 09:45 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
Glad you got it fixed. My guess a code reader is going to have to clear the light or you still have an issue.
Old 06-10-2013, 10:12 PM
Pman's Avatar
Pman Pman is offline
Vehicle: 1996 Dodge Ram 3500 Dually V10
Engine: 2003-2003 488ci (8.0L) Magnum V10 310hp 450lb/ft
Pman is on a distinguished road
You might need to have your ECM flashed? They (the dealer here) said I would need to do that if I installed a new one. Not even sure what "flash" is. Sorry, I'm new and surfing for potential issues, fixes and upgrades.
Old 06-10-2013, 11:19 PM
Pman's Avatar
Found this and it may be worth checking out.
http://dodgeram.info/tsb/1998/18-16-98.htm
Old 10-17-2013, 12:15 AM
northern2002's Avatar
northern2002 northern2002 is offline
Vehicle: 2002 dodge ram 2500
Trim Level: SLT plus
Color: gray
northern2002 is on a distinguished road
check your plugs see which ones are wet wih fuel chances are you will need the heads redone i have two V10 trucks and its the heads valve issue.
