Headlight Bulb Replacement - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 11-29-2012, 07:23 PM
mumaluke mumaluke is offline
Vehicle: 2011 Dodge Ram 1500
mumaluke is on a distinguished road
Default Headlight Bulb Replacement
So I just go my new 2011 RAM 1500, I am trying to replace the light bulbs. Is there a how to on this? I have read everything online, but cannot find a real how to.
Do I really need remove the grill? This seems waaayyy harder than it should be.
Thanks for any help!
Old 11-29-2012, 07:27 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I found this on another site:
You have to remove the entire lamp assembly to change the bulbs.
1.) Disconnect and isolate the battery negative cable.
2.) Romove the four plastic push- fastenersthat secure teh upper radiator seal to the grille support and both fender ledges.
3.) Remove the two plastic push-pin rivets that secure the upper radiator seal to the radiator
4.) Remove the upper radiator seal from the vehicle. (steps 2 thru 4 are just how to remove the plastic cover between the radiator and grille)
It is not necessary to remove the grille from the front of the vehicle to service the front lamp units.
5.) Remove the screw that secures the upper mounting tab of the front lamp unit to the Front End Module (FEM) carrier (also known as the radiator closure).
6.) Using a socket with a magnetic insert or with a small piece of butyl tape inserted, (I used a telescoping magnet once the screw was loosend I touched the magnet to the screw before removing the socket, this made it easy to retrieve the screw) reach down between the grille and the FEM carrier to access, remove and retrieve the screw that secures the lower mounting tab of the front lamp.
7.) Remove the fastener that secures the tab at the bottom of the access panel to the front of the front wheel house splash shield (inner plastic fender liner)
8.) Reach through the access opening of the wheel house splash shield and lift the slide lock upward (if you shine a flash light inside the opening you will see a white piece of plastic, this is the slide lock they are refering to) far enough to disengage it from the lock post integral to the back of the front lamp housing.
9.) From the front of the vehicle, grasp the outboard edge of teh front lamp unit firmly and pull it straight forward to disengage the ball stud from the plastic grommet in the FEM carrier. (I thought for sure I was going to break something at this step, instead of pulling from the front I place one hand in front of the assembly and reached inside the access panel and pushed the light forward to disengage it from the ball stud.)
10.) Pull the lamp away from the front of the vehicle far enough to access and disconnect the bulbs. (most already know how to remove the bulb from the lamp assembly)
Old 11-29-2012, 07:57 PM
Holly Crap!! Like I said, way harder than it should be!!
Thanks for the step by step! Looks like I will be waiting to the weekend to do this.
Old 11-30-2012, 06:13 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I had started a thread similar to this one awhile back...
Stump3r's post here, is a good source of info
Exco
Bill
Old 11-30-2012, 08:09 AM
Grubrunner's Avatar
Rep:3883
Exco
Stump3r makes it sound so easy....
I guess with the right tools and preperation, most projects are.
Grub out!
Old 11-30-2012, 12:10 PM
Rep:326
That is depressing.
Old 11-30-2012, 06:49 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
I adjusted the headlights on my 2011 a week ago and that was very easy. Excellent design by RAM as far as that goes although you can only adjust up & down but not sideways - figure that one out? After that, I looked at how easy it would be to replace the headlight bulbs and I could not believe there was no easy access to the back of the headlight assemblies. What a design screw-up. My 2003 RAM was eaiser than heck to replace the bulbs in as the assemblies were easily accessible at the rear. Still shaking my head on this one.
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 11-30-2012, 09:40 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
I'm still dreading the day I have to Change mine. As much as I want to upgrade my bulbs it's not worth it. My ford took 5 min. My Chevy took 5 min. Why is ram going backwards. Oh I know. Dealer services.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
