Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 11-29-2012, 10:44 PM
DustinUnderwood DustinUnderwood is offline
Vehicle: 2003 Dodge Ram 1500 Hemi
DustinUnderwood is on a distinguished road
Default 2003 lift question
I have a 2003 dodge ram 1500 with air bags in the back and a leveling kit in the front which were on when I bought the truck. My question is can I have a suspension lift with both those on the truck? I have 275/60 r20 tires which are 33's and I want to eventually get 35's. So I was thinking about a 2.5-3'' lift.
Old 11-30-2012, 05:48 PM
namccanna's Avatar
namccanna namccanna is offline
Vehicle: 2013 Dodge Ram 1500 SLT
Trim Level: SLT Big Horn Edition
Color: Black & Chrome
Rep:50
namccanna will become famous soon enough
According to most manufacturers of leveling kits for our trucks, u should b able to fit 35's under it with just the leveling kit. 35's (depending on width) will fit under the rear at stock height.
I just installed Rancho QuickLifts on the front of my '07 which lifts the front end 1.1" (according to the generic web info) or 1.5" (according to the specific order details), but both sets of information and a talk with Rancho said that 35's would fit under the front with just the addition of these struts. Idk if the springs have settled all that they will yet, but I could put 35's under my truck right now, no problem.
I would look into a body lift before suspension (cost) if all ur looking to do is put 35's on ur truck and u still need clearance with what u have.
Hope this helps a little.
I WELD FOR MONEY! IF YOU WANT LOYALTY.....BUY A DOG!
Old 11-30-2012, 09:55 PM
When it sits on level ground. It looks like I could put 35's under the rear but there would be little to no room for flex and the front would be very tight. How hard is it to instal a body lift?
Old 12-01-2012, 12:23 PM
namccanna's Avatar
Rep:50
Body lifts r pucks that install in each mount between the frame and body....if the bolts work free easily it shouldn't b all that bad to install....price wise tho u could save hundreds depending on what lifts u look at buying. Sometimes there r clips and wires u have to move or relocate slightly due to the added space between the frame and body. U want to make sure that wire harnesses r not stretched and being pulled on or rubbing on other components. This prevents damage to the wire harnesses.
Old 12-01-2012, 07:04 PM
Okay well hope nothing is too rusted under there lol. What size BL would you recommend?
Old 12-02-2012, 04:05 PM
namccanna's Avatar
Rep:50
I think that it is personal preference. I put a 3" on my Ranger when I had it. But I made sure that I could without creating all kinds of issues in the wiring and other components. I also found one that came with (not sure what they're called) gap flaps (covers the gap between the body and frame rails) and bumper brackets so that the bumpers r raised also.
Old 12-02-2012, 07:17 PM
I came over from the jeep wrangler forum and everyone despised the 3" body lift lol but Iwill defiantly look into it and see what I can do.
Old 12-03-2012, 06:00 PM
namccanna's Avatar
Rep:50
It depends on what u r trying to accomplish, what other options u have and what those other options cost....I did the 3" on my Ranger so that I could put 33's under it. It was WAY cheaper than doing a suspension lift...I think I paid right around $175 for the BL....suspension lifts started at something like $700 plus shocks. Personal choice to accomplish my desired outcome.
Old 12-05-2012, 02:49 PM
If I go with a body lift(Which I most likley will) How do I lift the bumpers?
Old 12-05-2012, 07:10 PM
namccanna's Avatar
Rep:50
Try to find a lift that includes the bumper brackets....otherwise u will have to fab ur own...nothing crazy, 3/16 or 1/4" flat stock should b more than sufficient. Slot ur holes tho to allow for fine tuning.....don't want it leaning one way or the other!
