Underheating - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-26-2012, 02:31 AM
Rep:2962
put a winter cover over your grille
this is one kind
http://www.autotrucktoys.com/ram/Mop...-PRD30250.aspx
some people just insert cardboard in front of the radiator, it let the engine warm up quicker & therefore the passenger compartment warms up quicker
it doesn't overheat the engine in colder weather
Old 12-29-2012, 11:33 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Originally Posted by ramvan2500 View Post
The engine has only the thermostat.
True
But when you connect the heating system there is a heater valve. If the heater valve is open the hot coolant will get directed to the heater core.
Pictures?
I have had instances where I left the temperature selector to heat and drove for hours and I never once reached temperature.
Never had an issue with that, with all the vehicles I've owned.
Old 12-29-2012, 11:41 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Originally Posted by panhead View Post
True
Pictures?
Well I don't know what to tell you, I guess you have an aluminum heater core, I have two copper heater cores and a 3-row racing radiator. But when the heater core valve is open say I'm running in 210F, if I open up the heater cores I drop down to about 145F.
I can show you pictures of a heater core valve but I don't think that is going to do you any good, though everything on the dodge van is the same as the pickup except the body, the heater valve will be located in a different place.
Underheating for this guy I doubt, that is why I said to check the temperature sensor. I had a busted up sensor and I kept getting a very very low reading, replaced the sensor and found out that I was really overheating because of a clogged radiator (hense the new aluminum 3 row racing radiator). The sensor is a brass probe but the internals are plastic injected, when that sensor gets hot the plastic overtime becomes like rubber and cracks.
But if it isn't the sensor it could be the heater control valve is open or leaking and some of the hot coolant is being cooled down in the heater core. Again I doubt this but it is a possibility. The reason why I doubt this is because the heater core outlet is where the gauge temp sensor is.
