Old 11-30-2012, 08:42 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
Default Throttle Body...
Hey guys I've been toying with the idea to port my throttle body as money is a little tight right now. I work in a machine shop and was curious if I could just bore the throttle body out to the size of an after market one...
thanks!!
Old 11-30-2012, 08:59 AM
Rep:176
well i just noticed that it will need a bit more then boring it out...even still my buddy ports heads for a living at an engine shop...
Old 12-02-2012, 01:59 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
Like you said, there is alot more to porting a throttle body then just a straight bore. A tapered design will make more power and give better throttle response, and you also have to be careful not to remove much material at the blade to prevent from throwing any check engine lights.
