Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 12-01-2012, 01:25 AM
DodgeV10 DodgeV10 is offline
Vehicle: 2015 Dodge Ram 2500HD
DodgeV10 is on a distinguished road
Default Would like to put in the better Cluster.
Maybe this was answered before but I have searched. Links are always good. One of the things I wish I really pushed for was a premium cluster. But being the last of the 2012, the only one they could have found had 2 wheel drive. (I was looking for a long bed and a regular cab.) Has anyone switched out a regulator cluster for the premium? I really want the EVIC. Can I upgrade the steering wheel to a leather one with the switches? What is all involved in this project? Plug and play? I already put in the Factory electric brakes with the rewire mod. so I have some skill. Any help would be great!
Old 12-01-2012, 04:18 PM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
it can be done get the cluster and plug it in buy tire pressure module for individual tire pressure get dealer to flash rdz and xbm sales codes theres also a wire splice to make at the clock spring so the horn will work and u have to get a cluster that is the same miles as yours miles as they are stored in the cluster but it can be done
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
Old 12-01-2012, 04:36 PM
Thanks for your input PostalTwo. I also talked to the dealer and I can send in the newer cluster to get the miles updated. I am thinking of adding miles so when I get it back I have time to get it in and set it all up. Do you know the wire splice that needs to be done?
Old 12-01-2012, 04:42 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
If i remember correctly, you can go to a Certified speedometer shop & they can do the official paperwork needed to install any speedometer/odometer, to keep it all nice & legal
there are certain things that you MUST do, otherwise it can be called an attempt to defraud
here is the LAW
http://www.rolledbackodometer.com/fe...meter-law.html
Old 12-01-2012, 08:04 PM
Trim Level: sport
Rep:14
at the clockspring in the colum
So here is the final mod setup for the evic install. This basically has three wires that are spliced. One is a ground, the other is the LIN BUS and the last is a fuse B+ wire. I would start by creating a harness of two wires or red and green, about three feet in length. Then splice the wires that are shown in the pics provided on the link below. Make sure these wires are firmly installed to prevent it being lose and bad contact. Lastly make sure you find a suitable ground location. Once complete, you should see the steering wheel buttons light up. All buttons should work and horn should be operational. Note: None of the buttons or horn will work without the EVIC installed nor will most everything in your cab will work. The EVIC is where most everything runs through. If you install the old ST cluster, everything will work except the horn and buttons, you should still see the buttons light up though. BUT, without the proper sales code added to your vin then nothing will work with the EVIC. This can be done at your local dealer, provided they have common sense and want to help. The mileage will be up to you Some people like to just burn up miles on their old cluster to catch up to a used EVIC.
Here is the link for the pictures for the wire splice mod that you need
https://picasaweb.google.com/1156511...eat=directlink
Old 12-02-2012, 09:20 PM
Don't worry GTyankee, I plan on updating the miles to my truck. Thanks PostalTwo for the GREAT write up and Pictures! Now there only one thing left to do. Find the switches that are on the left side of the steering wheel. Anybody have a clue on the number so I may order it from Dodge? Thanks.
Also do you have the exact place the tire pressure module sits on the truck so that I could pick one up from the junk yard? Or maybe the number to a new one?
Old 12-26-2013, 11:22 PM
Well I got the parts for a cluster upgrade and I need one more piece. The TPMS! Does ANYONE have a picture of where they are located??? What the Plug-in that is needed to connect to it looks like? The threads for TPMS here seem to be for the sender in the tire. Any help would be great.
Old 12-27-2013, 12:17 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Does this help?
http://www.ramforumz.com/showthread.php?t=70964
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 12-27-2013, 01:35 AM
Thats it! To late to look under there tonight. But first thing tomorrow before work, I am taking a peek! Thanks LowUFO! Now all I have to do is find a TPMS...
Old 12-30-2013, 02:45 PM
huntergreen huntergreen is online now
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:749
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
wow, before i started taking my dash apart, i would look into one of those monitors that you install and gives you all the engine info. just another option. i would just to hate to take apart my dash and end up with a rattle.
