Old 12-01-2012, 08:47 AM
CoolJoe316 CoolJoe316 is offline
Vehicle: 1996 Dodge Ram 1500 4x4
CoolJoe316 is on a distinguished road
Angry Steering problem on 1996 dodge ram 1500
I replaced the track bar, center link, drag link, adjusting sleeves, outer tie rod, gear box, got an aliment and the steering wheel has a lot of play in it. Also it doesn't lock either when the engine is off. help!!!
Old 12-01-2012, 08:51 AM
Rep:1824
The play in the steering can be from worn ball joints, excessive play in the steering gear box, or a combination of these things. The steering wheel not locking with be a problem located with the lock mechanism in the column.
Old 12-02-2012, 01:02 PM
everything is new ball joints and gear box. pretty much the entire front end has be replace in this truck the locking steering i will look into
