Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 10-13-2012, 12:13 PM
KStamps01 KStamps01 is offline
Vehicle: 1995 Dodge Ram 3500
KStamps01 is on a distinguished road
Default Right side of my trailer lights won't work
I have a 1995 dodge ram 3500 4x4 v10 flatbed. I have towed two gooseneck style horse trailers that on both my right lights did not work. My left lights the running, brake and turn signal worked fine. Was thinking it maybe an issue with a ground somewhere because my right head light is dim. All the lights on the truck work fine except for the dim headlight on the right. The truck has both a 7-pin and 4-pin. Any ideas where to start would be helpful. Thanks
Kris
Old 10-14-2012, 08:17 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Let us know how you make out and please keep us updated......
Old 10-14-2012, 08:20 PM
Tdog93 Tdog93 is offline
Vehicle: 2003 Dodge ram 2500
Color: Burgundy
Tdog93 is on a distinguished road
My 2006 2500 does this same thing.... Took it to the dealer and they said it was a short out some where They quoted me $400 to fix it. So I just left it as is and just use my 2003 to haul trailers
Old 10-14-2012, 08:45 PM
Rep:2625
sometimes the wiring in the trailer can be different than the vehicle towing it
wires need to be switched in the trailer pigtail to match the towing vehicle
best way to check the tow vehicle female pigtail is to turn on the ignition,
then find your pin with the power source, using a device like this
http://www.amazon.com/Tools-KDT129-V.../dp/B000K1CHK0
grab a pencil or pen & a piece of paper, you are going to need to draw a diagram of the towing vehicles pigtail
1 of the pins should light up, your license plate light should also be working if the light switch is on, mark which pin is the hot one
then you can turn on your turn on your Left turn signal & find which pin makes that work
mark that pin on the diagram
continue trying different things & mark them down if it works
when you get to doing the Right side, do the same tests
that will tell you if you have power to both sides
if you do, it is something wrong with the trailer pigtail or the bulbs
common pigtail diagrams
http://www.etrailer.com/faq-wiring.aspx
Old 10-14-2012, 08:47 PM
Turned out to be a broken wire on a trailer. Guess it was just bad luck it was two trailers in a row.
Old 10-14-2012, 08:54 PM
Rep:2625
Great, a simple fix is always the best kind
