Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-01-2012, 06:33 PM
jwmiller61 jwmiller61 is offline
Vehicle: 1995 dodge ram 2500 diesel
Trim Level: xlt
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
jwmiller61 is on a distinguished road
Default a/c and overdrive issues
1995 2500 4x4 diesel. Sometimes when I crank up the truck, the a/c compressor won't engage and the truck will not go into overdrive at the same time. Other times I crank and drive the truck, both the a/c and the overdrive work like they should. What controls both the a/c and the overdrive?
Old 12-01-2012, 08:14 PM
Resident Technician
Rep:1909
My first guess is a faulty ignition switch and/or connector, specifically on the A21 circuit which provides switched ignition power to both components.
