Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 12-18-2012, 11:05 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I haul with my truck a lot, and never have any issues. I even have my stock springs removed and replaced with RT springs(~1200 lb payload IIRC) which are then cut for a 1" drop in the rear(about 1.5 coils IIRC), and still have no issues. Here's my truck with maybe 1,200 lb payload in it(on the cut RT springs):
That was on a 2,600 mile trip and it rode fine, not too much squat(even at the limit of my cut springs), plenty of travel left.
My old truck with leaf springs squatted more with the same weight.
I do agree though there is more travel with the coil setup vs the leaf setup. I don't understand why people have an issue with squat though, you are putting weight on a spring, it will squat...
Sean
Old 12-20-2012, 04:18 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
I think the reason the ram 2500 payload is so low is that the truck is identical in frame and body to the ram 1500 with a different suspension setup (leafs in place of rear coils). Whereas all of the other manufacturers (Ford, GM/Chev) all have frames for their 250/2500 models that emulate the 350/3500 super or heavy duty lines
Old 12-20-2012, 11:18 PM
snrusnak's Avatar
Rep:1385
I thought the 2500 frame was different from the 1500 frame.
Sean
Old 12-21-2012, 02:53 AM
Rep:2625
I run 1,000 pounds, (1/2 ton) of weight ALL the time in my bed, it doesn't squat a bit
2012 Ram 2500
Big Horn®
5.7L HEMI® V8 VVT
crew | 6'4" | auto |4x2
Max Payload 2,846 lbs
Max Tow 10,900 lbs
http://www.ramtrucks.com/en/towing_guide/
