Tire pressure on 22" RT's. crew cab - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-01-2012, 11:18 PM
57hemisport's Avatar
57hemisport 57hemisport is offline
Vehicle: 2009 RAM 1500
Trim Level: sport
Color: brilliant black
Rep:60
57hemisport will become famous soon enough
Default Tire pressure on 22" RT's. crew cab
What is the proper tire pressure for a crew cab with the stock fortera 285 45 ?
Old 12-02-2012, 10:02 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Look in the door jamb it shows the stock psi's.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 12-02-2012, 10:49 AM
Vehicle: 2012 Dodge Ram Sport
Rep:47
It doesn't show stock psi for 22's. I don't know if size matters at all but I have never thought about it. I believe I have 40 psi in my nitto 420's.
Old 12-02-2012, 07:06 PM
Trim Level: sport
Rep:60
The psi in the door jamb is for the stock 275 60 20, which is 35 psi cold. I know there is a formula using the weight of the truck and the load index of the tire. Both tires have totally different load index. I just don't know how to figure that out.
Old 12-03-2012, 05:48 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
You can also check the tire manufactures web site, some post that info.
In general the tire pressure listed on the door jam is a good starting point and pretty close to what you should run. The PSI requirement won't change based upon the tire size, the the volume of air will. The load rating and tire structure will play a role in how much pressure is needed for what you are looking for (tread wear, softer ride, hauling, etc).
The easiest way would be to chalk the tires, start at the recommended psi, then go up or down a few psi, then adjust from there.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 12-03-2012, 08:23 AM
Grubrunner's Avatar
Rep:3883
Though I've never tried it, some people who have changed/updated their tire/wheel combination swear by the drawing of a chalk line method --
Copied & Pasted - You can always use the chalk line method: Start off with the OEM pressure, draw a even pressure chalk line across the tires and drive app. 30 feet. The wear on the chalk line should be even. If you have some left on the outside edges of the tire, you have too much pressure, if you have some on the center, you have too little pressure. Again, wear along the tire/chalk should be even...
For the record, on all previous vehicles I've owned - where the wheels and/or tires have been changed and altered in size from OEM - I've always inflated tires 2-8 PSI above the door placard.
Grub out!
Old 12-06-2012, 09:15 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
I'm running about 37-38 in mine and the tire seems to be wearing pretty even. Had them on for about 10K now.
Old 12-08-2012, 12:52 AM
InDeepWaterBlue's Avatar
Rep:611
What he said, I'm running 38psi on the 22's and they were evenly minus my empty parking lot antics
Old 12-08-2012, 01:18 AM
Trim Level: sport
Rep:60
Cool, thanks. I noticed the truck rides smoother on 39-40 psi. Anything under the ride is more harsh.
Old 12-08-2012, 02:43 PM
Rep:47
I'm running 40 psi in my nitto 420s 22's.
