Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 12-02-2012, 01:09 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Default Shimmy when I brake...help
So I started to get a shimmy in the front end when I apply brakes. Figured...time for rotors to be changed cuz they are warped. Changed them today..didn't fix it.
What else can cause this shimmy? It happens probably 80% of the time. Every once in awhile it won't do it. At highway speeds it's real noticeable. But the frequency of the vibration is proportional to the speed I'm going. If i'm going fast...its vibrates quick, rolling to a stop...it's more of a pulse.
Old 12-02-2012, 02:51 AM
indianaram1500's Avatar
indianaram1500 indianaram1500 is offline
Vehicle: 2007 Dodge Ram 1500 SLT 4x4
Color: Inferno Red Crystal Pearl Coat
indianaram1500 is on a distinguished road
New rotors can be warped too.
Old 12-02-2012, 09:31 AM
Resident Technician
Rep:1915
Agreed, although you should have seen some sort of change in the vibration. If you feel this pulsation in the brake pedal, you may need to have the rear rotors replaced or machined as well. Beyond this, other causes could be in the hub itself or a problem with the steering and/or suspension components.
Old 12-02-2012, 02:20 PM
Rep:1900
ok well I think I'm gonna driver her again on the highway and pay more attention to if its in the wheel or the pedal. could tie rod ends be suspect if its more in the wheel? then change rear rotors if more in the pedal? thanks guys
Old 12-02-2012, 07:20 PM
Resident Technician
Rep:1915
Yes, tie rod ends or any loose steering or suspension component could cause this.
Old 12-02-2012, 08:13 PM
Rep:1900
Awesome. Thanks RamTech.
