Help- Just bought 01 5.2 1500, now won't start, stuck on street! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 12-03-2012, 12:16 PM
Cruciform Cruciform is offline
Vehicle: 2001 Ram 5.2
Rep:17
Cruciform is on a distinguished road
Originally Posted by RamTech View Post
The attached .pdf file is one of the factory diagnostic procedures for a no start condition.
Well, I guess I know what I'll be doing tonight.
Thank you very much, that should prove to be very helpful.
Old 12-03-2012, 12:22 PM
Resident Technician
Rep:1915
Let us know what you find.
Old 12-04-2012, 03:47 PM
Rep:17
Ok, I had an opportunity to look at the truck today-
Here's what I came up with-
A) pushed the shraeder valve on the fuel line in, a little fuel came out, but seemingly not a lot of pressure.
B) when cranking, hooking a voltmeter to the wires that go to the coil, I get about 5volts while cranking. I would think it should be 12v consistently As soon as I let off the key, it quickly jumps to 11 or 12, then 0. I'm thinking this could be my problem-not enough voltage to the coil.
Does this mean a crank sensor or could it be a grounding issue? I cleaned several ground locations-
-PCM to body
-Body to engine
-Battery to engine
-Battery to frame
No change.
Old 12-05-2012, 10:50 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Could be a mirad of problems...
Try tapping on the fuel tank while someone cranks it and make sure it's getting fuel.
Crank position sensor could be going bad.
Temp sensor could be dry or bad ($17)
Plug on the coil could be bad and needs to be wiggled around and then replaced.
Make sure it's got adequate spark...
Old 12-05-2012, 10:57 AM
Resident Technician
Rep:1915
If you want to verify ground condition, do a simple voltage drop test. Set your DVOM up fo the 12V scale and attach the positive lead to the ground location you want to test and the negative to the negative battery terminal and turn on the key. You don't want to see more than about 1/2 volt drop max. This test can also be used to check positive wires using the positive battery terminal. Have you pulled the steering column covers to check the ignition switch for melting?
Old 12-05-2012, 09:34 PM
Rep:17
There wasn't any OHMage between the terminals of the coil. In searching for a new one, I discovered that its the same for my Jeep Wrangler, which is right next to it in the garage. Pulled that out, put it in and it fired right up.
thanks for all your all your help folks!
Old 12-06-2012, 12:01 PM
Vehicle: 95
Rep:1776
And you'll notice that I gave you some Rep Points for posting your solution. Nice Job
Old 01-17-2013, 03:18 AM
thatoneguy11 thatoneguy11 is offline
Vehicle: 2001 dodge ram 1500
Color: bkacj
thatoneguy11 is on a distinguished road
Im having trouble with my 01 ram I melted a ground wire that comes off of the block and my truck wont even turn over it just buzzes at the pcm does ne1 kno what it could be
