'02 2500 5.9 Gas PCM Change out? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-02-2012, 01:50 PM
JDodge JDodge is offline
Vehicle: 2002 Dodge Ram 2500 Ext. Cab
JDodge is on a distinguished road
Default '02 2500 5.9 Gas PCM Change out?
Is the PCM hard to change out? Is it better to buy rebuilt(pre-programed) or new? If new do I have to buy from the dealer? Help please I am trying to sell this truck that I have had no problems with until now.
Thanks,
JD
Old 12-03-2012, 01:33 PM
bdodge445 bdodge445 is offline
Vehicle: 1995 Dodge Ram
Trim Level: Laramie SLT
Color: Black/Gray
bdodge445 is on a distinguished road
They are pretty straight forward, just a wire harness and some screws. What makes you think you need a new one, what are your problems? Could be solved by taking it to a dealer and having it reflashed $45/100. I just had mine reflashed after installing a new engine, cost $43 and change at my local dealer. As far as used I'm not to clear on which you can use, I'm sure one of our better seasoned members will chime in.
Old 12-06-2012, 12:47 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Mopar does offer refurb PCM's.
Old 01-03-2013, 04:42 AM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
Not sure about an 02 but I have heard that some of the PCMs are VIN specific.. basically you cant swap them out with used ones because its not specifically programmed for that vehicle with that VIN.
Like I said Im not sure about an 02 but if its something you can fix by having it flashed by a dealer Id just do that. That is gonna be your cheapest way.
Im having an issue with mine also but I have a 98 2500 with the 360 and auto trans. PCM isnt sending the signal for the trans to shift from 1-2 and 2-3.. so Ill keep an eye on this thread to see If I can figure which way to go with mine.
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
Old 01-03-2013, 07:30 PM
panhead's Avatar
Rep:103
You can get refurbish PCM's specifically for your truck from Mopar.
