Old 12-02-2012, 02:45 PM
smitty0486's Avatar
smitty0486 smitty0486 is offline
Vehicle: 2014 Ram 2500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
smitty0486 is on a distinguished road
Post tire question?
Will a 315/70/17 tire fit on my truck without a leveling kit?, they measure out to a 34.7 or something like that. Thanks for the help ahead of time!
Old 12-02-2012, 02:47 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
hieght should be fine its width that will be your problem u will need negative offset on ur rims or spacers
Old 12-03-2012, 07:43 AM
smitty0486's Avatar
Any idea how much of an offset ill have to have, I've never used them before?
Old 12-04-2012, 03:19 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
It depends on the wheel width. I beleive the stock wheels are 17x8.5 with a 0 offset. I believe that you would need about 1/4 of more inner clearance to fit the 315 (essentially 12.5" wide). So if you stuck with a 8.5" wide wheel you would need something with an offset of -6mm or lower (lower the number the more the wheel is pushed outward) If you go up to a 9" wide wheel then you would need something with a -12mm offset or lower.
Starting with a 0 offset (mounting surface is centered between the inner and outer lip of the wheel) the lower the number (neg) the further the wheel will be pushed out from the suspension. If you go too low then the wheel will stick outside the fender. On the contrary the higher the number (+ offset numbers) the more the wheel will be sunken in resulting in less clearance between the rim and suspension. If you go too high on the offset then the wheel wont fit.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
315/70/17, leveling kit, tires
