Is limited slip additive needed? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 12-02-2012, 08:43 PM
indybp57 indybp57 is offline
Vehicle: 2004 Ram Quad Cab 2WD
Color: Graphite
indybp57 is on a distinguished road
Default Is limited slip additive needed?
I need to change the diff fluid in my 3.92 limited slip rear end. I know the manual says the Mopar additive for limited slip is required, but I notice that some of the gear oils (Lucas) says no additives are needed. Should I go ahead and use the additive anyway? Is there such a thing as too much additive?
Old 12-03-2012, 01:02 PM
Resident Technician
Rep:1915
Would you take a chance on a $600+ repair to save a few bucks on additive? Me neither.
Old 12-03-2012, 07:01 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2015 GMC Sierra
Color: Bronze Alloy Metallic
Rep:2035
So the answer to the question is...?
I know royal purple states that it already has a LSD additive so adding the Mopar friction modifier would just be added insurance?
Chrome... in moderation.
Old 12-03-2012, 07:11 PM
Color: Graphite
No. But if I knew for certain that the lube already had it I wouldn't add more. That's why I went and bought a bottle today. The recommended dosage is 2-5% of the total volume so you could apparently overdo it. I'll make sure the lube I buy is not the "no additives needed" kind.
Old 12-03-2012, 10:57 PM
bighemi04's Avatar
Vehicle: 2017 1500 Laramie
Rep:623
I would check out what you can get through Amsoil. Discount auto performance is a dealer and a vendor on here.
