early upshifting problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-02-2012, 09:17 PM
gaugedearguy's Avatar
gaugedearguy gaugedearguy is offline
Vehicle: 2013 ram 1500 sport quad cab
Trim Level: sport
Color: Mineral gray pearl
gaugedearguy is on a distinguished road
Default early upshifting problem
has anyone experienced a problem with the auto trans in an 06 ram 1500 upshifting early? this is my first dodge ive had it for almost four years and it has always done it. i was just wondering if its a normal thing or if i have a valve body issue or something. example would be going up a hill sometimes instead of downshifting like it should it up shifts and i have to almost floor it to down shift. then when i let off it up shifts right back where it was. cant be normal to run up a hill at 1000 rmp lol. just curious.
! DODGE FROM HERE ON OUT !
Old 12-03-2012, 08:49 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:518
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
If you're running at 1000 RPM then you're almost certainly running with the Torque Converter Clutch (TCC) locked. I'm wondering if the "downshifting" you're noticing (at heavy throttle) is actually a TCC unlock (and "upshifting" is the re-lock).
The shift schedule is based on trans output speed, and throttle opening. So it could be your TPS is giving a bad (too low) throttle reading. Best way to diagnose would be to have a dealer tech ride with you (with a scan tool). He can tell what's really happening (what gear[s] you're in, whether the TCC is locked or unlocked, what the TPS reading is showing, etc.) and hopefully figure out why it's behaving as it is. He can also make a recording of the shifting, and upload that to our STAR Center (tech support line) for additional assistance if needed.
Old 12-03-2012, 08:20 PM
Trim Level: sport
so the tps could cause the problem? because i do have an idle problem. from what i have read here and other places its my iac. my idle goes up and down from about 700 800 to 1500 rmps.
Old 12-04-2012, 09:12 AM
Vehicle: N/A
Rep:518
Yes, I would fix any IAC / TPS problems first. Once the throttle realm is back to normal, then see if you still have issues with the trans shift schedule.
Old 12-04-2012, 08:47 PM
Trim Level: sport
i really appreciate the help. its nice to learn something new from someone very knowledgeable.
