89 Dodge 100 HELP! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 12-03-2012, 12:12 PM
jscar305 jscar305 is offline
Vehicle: 1989 Ram 100
Trim Level: Rust
Color: Blue
jscar305 is on a distinguished road
Default 89 Dodge 100 HELP!
I have high beams but no low beams. Switch is on the column. Whats my problem?
Also..is the fuel sender a stand alone device or is it integrated with an in tank fuel pump?
Thanks
Old 12-03-2012, 08:50 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Rep:2055
ShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond repute
Welcome joining here is a great decision for any RAM owner so much knowledge and information here!
Here are some how to threads to some common questions
How to upload pictures to your gallery
How to insert image in post
Old 12-05-2012, 03:06 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Thanks
You need to check the voltage (pull the bulb and check the plug) to see if ur getting 12 volts with the low beams on. If the high beams are working you're getting 12 volts to them...hope that makes sense. If you are getting 12 volts with the low beams on, the switch is good and the bulbs are defective. If not the switch is bad, and check both sides. (i think, lol) I'm not sure about the fuel sender but they're usually in the tank and pita to change. Forgot, check your fuel sender wiring under the truck and behind the instrument panel and make sure all is connected.
Old 12-05-2012, 10:29 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
^Like stated^ check the power at the plug on the back of the headlight. You'll have one negative and two positive with the high beams on. Low beams would be one neg and one pos (two outer vertical prongs). If all is well there check the ground, even if you have to run a jumper from the socket to the ground (with just the low beams on) Chrysler in their infinite wisdom sometimes has unique problems and the low beam wire will act as a ground and make the high-beams work. Again...if all is well there. Check the switch on the column. Especially if it's been sitting.
On the 89 D100 I'm pretty sure you still have the mechanical pump (D100=6cyl?) bolted to the block...so I guess it could/would be considered a "stand alone" pump...kinda like me at family gatherings...waaaay alone.
If it is the mechanical pump it's a relatively straight forward swap and probably sells new for under $30.
