Old 12-29-2012, 01:00 AM
Originally Posted by Racerdamon View Post
Got the White in and looks good but the chrome has some scratches on it and I have figured out how to get them off so they are going to be painted red!
[/IMG]
This looks sweet! I wanna see this lot up when done
Old 12-29-2012, 01:26 AM
57hemisport's Avatar
57hemisport 57hemisport is offline
Vehicle: 2009 RAM 1500
Trim Level: sport
Color: brilliant black
Rep:60
57hemisport will become famous soon enough
I just installed mine. I ordered them in white. To be honest I thought they were going to be of higher quality. My first complaint was they had small scratches on the chrome bezels. They had finger prints like crazy that were hard to take off! they compare nothing to the quality of the oem. When the overlay is set on the digital board it doesn't sit correctly. The bezel of the evic doesn't sit on the chrome rings correctly causing it to crack on the two upper corners. The instructions call to remove the needles with just your fingers but I couldn't do it. I used a small flat screw driver, put a microfiber on top of the chrome bezel and used them for leverage. I do prefer the sportier look and the design but they lack in quality.
Old 12-29-2012, 05:46 AM
InDeepWaterBlue's Avatar
Rep:611
[/IMG]
Definitely post the pics up here or share the link to you page so I/we can check them out! Doing the Trim ring in red sounds like an awesome idea. Glad you figured out how to pop apart the plastic.
Originally Posted by moparornocar72 View Post
Reps coming to you when I can Indeepwater, this is pretty sweet, maybe when I get done with school and can keep modding on my truck again! Sweet gauges!
Thanks bud it's definitely one of my favorite mods, hopefully they work on their quality control a bit from what I've read it's sadly lackin on the guys ordering he white gauge faces.
You can remove the needles by hand, you have to twist to the left and then start to pull straight up while still twisting left and eventually you'll break the mechanical bond. It's a slight PITA but if you're not careful you'll screw up the little motor in them. You can send the whole unit to US Speedo and they'll fix it which is nice but then your missing a gauge cluster for a couple days. I'm sorry your EVIC trim ring didn't fit properly, I highly encourage giving them some constructive feedback so they can get it fixed You're also the second person to complain about the small scratches on the trim ring, I would suggest telling them about this as well as that seems to be a quality control issue. I'm surprised to hear this as they are a manufacturer of gauges, but if you send them pics I bet you could get a replacement sent to you.
Old 12-31-2012, 05:08 PM
thunder98110's Avatar
thunder98110 thunder98110 is offline
Vehicle: 2012 Dodge Ram
Trim Level: ST express
Rep:14
thunder98110 is on a distinguished road
does anyone know how it looks with the non evic gauge cluster? I dont think the non evic is as bright as the evic one (the light ring around the tach/spedo). i just dont want it to be dim.
2012 RCSB, Hemi,3.92,2wd,Fastman TB,180tstat,K&N CAI,AeroTurbine 3030xl + Magnaflow Y,v6efan, LEER 100xl
Old 12-31-2012, 05:37 PM
Rep:611
I don't think anyone has installed it with not non EVIC yet bud
Old 01-01-2013, 01:41 PM
Rep:14
Is it possible to replace the gauge cluster bulbs?
Old 01-01-2013, 02:00 PM
Rep:611
From what I remember in a previous post by SS4Luck in the interior light section it would be giant PITA to try and do it
Old 01-21-2013, 02:10 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Did I start a trend? LOL!!!
Here's mine btw.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 01-22-2013, 10:53 AM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Considering the Blue Speedo Gauges on my 05' Daytona...looks sick. I'm also wondering if the blue would look even better if I swapped out the cluster bulbs? Maybe white?
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Old 01-22-2013, 11:33 AM
bighemi04's Avatar
Rep:623
I do like the look of the colored gauges. Might have to think about it
