Daylight Running Lamps - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 12-05-2012, 02:52 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
gt... that is called "fund raising". what a rip off.
Old 12-05-2012, 04:24 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
Porter, i have been running with my ambiant light sensor covered since September 2009
there has been no bad effects
everything works as it should
well sure no bad effects. but you understand what i mean by dimming the radio etc., right? i'm talking about the interior panel lighting. the radio etc. will become difficult to read in typical daylight conditions.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 12-05-2012, 11:16 PM
billsfan69 billsfan69 is offline
Vehicle: 2013 Ram Laramie Crew Cab
Trim Level: Laramie Crew
billsfan69 is on a distinguished road
I am going to stop at the dealer again tomorrow and check it out. I wonder if changing the country code will effect anything else on the truck. Maybe try changing the country code to Canada, activate DRLs then change back to US mode. I will keep you posted.
Old 12-06-2012, 08:50 PM
So we changed the country code and option was still not there. It will be in the BCM if it is equipped. We went into the Dealer Installed Options screen on dealerconnect and added the option LMK to the list of sales codes. Ran out of time but now we are going to reconfigure the truck computer. I will let you know.
Old 12-12-2012, 10:18 AM
Rammie Rammie is offline
Vehicle: 2013 ram 1500 laramie
Color: Grey
Rammie is on a distinguished road
Got 2013 laramie anybody got solution?
Same problem here.
Old 12-12-2012, 04:37 PM
Ctrl-z Ctrl-z is offline
Vehicle: 2000 GMC 2500
Rep:16
Ctrl-z is on a distinguished road
Not sure if the problem is US owners wanting DRL and can't get them or Canadian owners requiring DRL and they aren't working but if it's the latter then this Transport Canada recall applies:
RAM
Units Affected - 3,000
1500 – 2013
Certain pickup trucks may not comply with Canada Motor Vehicle Safety Standard 108 – Lighting Systems and Retroreflective Devices. Due to an error in the configuration of the vehicle, the Daytime Running Light (DRL) system was not enabled. No DRL illumination could render the vehicle less visible to other motorists and pedestrians during daylight hours, which could result in a crash causing property damage and/or personal injury. Correction: Dealers will update the DRL configuration on affected vehicles.
Old 01-07-2013, 12:50 AM
davenator davenator is offline
Vehicle: 2012 Ram
Rep:18
davenator is on a distinguished road
Hi guys. I tried to find this answer somewhere, but I`ll post here and hopefully someone can help. I had my drl`s on the other night sitting behind a car, and I noticed a very slight flicker with my drls. I didn`t believe it, so I shined them against a wall. Sure enough...a very slight flicker, but otherwise all my lights work fine. Is this normal at all, and has it happened to anyone else? In case anyone is wondering...yes, they are all original bulbs....for now. I got my truck a month ago, and the mod itch is beginning. Starting with removing all the dealers advertising. Thanks.
Old 01-07-2013, 01:41 AM
purodude's Avatar
purodude purodude is offline
Vehicle: 2012 ram 1500 crew cab
Trim Level: sport
Color: bright white
Rep:16
purodude is on a distinguished road
You can make your stereo stay bright at all times by turning the wheel under the headlights switch all the way to the left . You will feel it click twice .hope this helps.
Old 01-07-2013, 09:50 AM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Another option is to buy a set of LED DRL's and wire them in. Might be cheaper than getting the dealer to spend time on it.
Old 01-07-2013, 12:27 PM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:65
gusman will become famous soon enough
Pretty sure in the center radio thing under settings where you can set like what happens when you start with the remote (horn honk, heated seats on) there was an option for DRL's on. Along with how long you want the lights to stay on after locking the truck etc.. 2013 sport
