Dodge Ram Decals
Old 12-04-2012, 02:32 AM
HenDom's Avatar
HenDom HenDom is offline
Vehicle: 2011 dodge ram 1500
Trim Level: sport
Color: deep cherry red
Rep:28
HenDom is on a distinguished road
Default 6" RCX or 3.5" Kore Lift
Decisions, decisions. Both have pro's and cons. Anyone else's thoughts? I am leaning towards Kore for the CV joints.
Old 12-04-2012, 02:41 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
What are the pro's and con's you discovered.
Many dont know much much about the Kore kit
As for CV joints....that's probably the bulk of their cost.
To me? You can piece all this at a cheaper buck.
sales@revelperformance.com
Old 12-04-2012, 08:33 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
unless you are going to be doing some serious off roading or desert racing i'd go rcx. kore and carli are big in the diesel world with people with money and run in the sand. if your going for a stance and might take it off road once and a while rcx will fit your need. your cv's will be fine.
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
Old 12-04-2012, 10:26 AM
Revel Performance
Rep:1804
To add to this....
You can always swap out to Kore CV's if and when your stock ones fail.
But with the standard 6" lift kit and nothing more, your stock CV's will be either at the same angle or better than stock.
Old 12-04-2012, 12:30 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
To add to this....
I like this idea you can also have a machine shop custom fab a bigger drop bracket to get even better angles this is a route I am thinking of going paired with a set of core cvs now that's a wicked set up
Old 12-04-2012, 01:14 PM
Revel Performance
Rep:1804
Only thing here....is id he doesnt use Bilsteins and only uses the 6" RCX kit, his angles of CV's will be straight and equivalent to stock.
That means, no stress on them.
The lift kits today are built with all this in mind
OP!
Its ultimately your call. Do you want a 3.5" lift over a 6" lift?
Do you off road heavily? Im not too sure the 3.5" will give you enough clearance for mudding, etc....I think this kit is made for the sand dunes and paired with the Kore front bumper for added clearance
Is it mainly for the stance?
Do you want to spend $2k vs $1400?
Old 12-04-2012, 04:45 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
OP!
I would go the 6" route but that's just me
Old 12-05-2012, 02:11 AM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Kore is an absolutely great product... I can't knock them for that. They are known for a rougher ride compared to other lifts (at least on the diesels when comparing), but they are a great kit. HOWEVER, in my opinion i wouldnt run Kore unless I was planning on some serious offroading..
I recently just ordered my RCX 6" and it is waiting for me at the shop. I also known personally the guy who designed the 6" for our trucks and wrote the instructions. After meeting with him it was obvious RCX was the route to go. As stated above, unless you plan to truly use the Kore kit, I think you would be disappointed. The perfect setup I think is the RCX kit with Kore CVs. The Kore Cvs are probably my next purchase just to be on the safe side.
You are comparing two absolutely great products. I've never ran RCX, but am 110% sold on them for my truck, so i bought the kit. I have never owned Kore either, but I have ridden on and off-road in about 3x different truck that run their kits. So there are truly two great products. They real question is, what are your intentions with the lift? What do you expect? and what do you plan to use it for, heavy off-road, occasional deer lease, or just highway pounder? By knowing what you will be using the kit for will help determine which one is right for you.
Kore:
- Better for heavy heavy off-road use, although remember you drive a 1/2 ton.
- Sturdier design (could be argued)
- Rougher ride (most likely)
- Pricey ($1,300 for a leveling kit --- UNLESS it is going hard off-road.. then useful.
RCX:
- 2.5" Higher
- Fantastic Design
- Roughly the same price as Kore with 2x the components
- Great highway pounder
- Great moderate off-road, deer lease kit
- Fits bigger tires
- With Kore CVs perfect.
These are just my opinions
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 12-05-2012, 02:12 AM
Ram725's Avatar
Rep:347
OP!
Kore is definitely not purposed for mud, can be used for it, but definitely not made for it.
You are correct, sand dunes are what Kore was made for.
Build Thread
Old 12-05-2012, 09:36 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Kore:
RCX:
- 2.5" Higher
- Fantastic Design
- Fits bigger tires
agreed and agreed
