89 ram tailgate latch problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Body & Interior
Body & Interior 1st Gen Dodge Ram Body & Interior Problems and Questions.
Old 12-05-2012, 12:20 PM
srdupnock srdupnock is offline
Vehicle: 1989 Dodge W-150
Color: Blue
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
srdupnock is on a distinguished road
Default 89 ram tailgate latch problems
The tailgate on this truck has always been a pain in the neck. You have to reach in the bed on the drivers side and manually open that latch then horse around with the handle to get the other side to release. How do I get the tailgate apart to try to fix it or to replace the innards? Or how do I adjust what I already have?
Old 01-06-2013, 12:53 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
usually the problem is in the handle. many owners do not lube the handle hardware enough and then the parts get strained and break or bend, There is a plate in the inside behind the handle to make repairs. to clean amd lube also.
Old 01-08-2013, 09:36 AM
Color: Blue
Alright. Ill take a look but I don't think I have the removable plate.
Old 01-10-2013, 10:08 PM
Trim Level: base
Color: blue/silver
You may ouly find screws to remove the handle. pull handle out and then you should have an idea if the problem is the handle or the latches. if you don't find any problem in the handle check if you pull the cable to see if the latch moves freely or is not attached you will have to determine and which end is disconnected and determine what needs repair.Many times you may want to use a bigger hamer but it won't help I've already tried it.
Old 01-10-2013, 10:49 PM
Rep:2962
if your sheet metal needs replacing
http://www.rockauto.com/catalog/x,ca...h%2Bfor%2BEMPI
Old 01-11-2013, 09:55 AM
Color: Blue
Alright. Ill just has to jump in and do it. Generally the drivers side latch needs to be opened by hand and the right one I have to pop the handle three or four times to get that one to open.
Old 01-12-2013, 10:52 PM
Trim Level: base
Color: blue/silver
It really isn't that bad a job. What you will find is there rods that go from the latches to the handle. usually these rods break or strech due to lack of lube on either latches and or the handle. I find it is some times easier to remove the tailgate to work on it. The one thing lube the latches good and life wll be great.
Old 06-03-2013, 10:16 PM
MeAndOldBlue MeAndOldBlue is offline
Vehicle: 1989 Dodge 100 Longbed
Trim Level: Base
Color: Light Blue
MeAndOldBlue is on a distinguished road
A friend of mine solved this problem for me. He connected a coathanger to the rod which had apparently broken and brought it in behind the handle, where he bent about the last 3/4" into a right angle (just enough to get your finger around). It is not ideal, but I pull on the right-angle-end-of-coathanger with my left hand, and pull the handle (still attached to the rod on the other side) with my right; but it beats messing with the latch itself and once you get used to it, it's second nature. It's worked for several years.
Old 06-03-2013, 11:55 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Appalachian American engineering... Gotta love it! Southern hospitality and Southern ingenuity go hand in hand.
