Old 12-05-2012, 08:22 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Default Pulling ABS plug to diasble TM
Who's done it and what are your thoughts?
Looks like the dash lights up like crazy but goes back to normal when it's plugged back in....anyone have any adverse effects from doing this?
Still no tuner so I'm thinking about giving it a shot at the track this Friday.
Old 12-05-2012, 09:38 PM
dusterman dusterman is offline
Vehicle: 2012 ram reg cab express
Rep:79
dusterman will become famous soon enough
I have done it and it helped a lot at the track. I went from a 7.86 500ft time to a 7.75 time. But I will worn you after acouple runs you need to disconnect the battery cause the check engine light will stay on till you do.
Performance:K&n cai, muffler delete, ported throttle body, 2800 edge stall 180t and white lightning tuning : soon longtubes
Interior: painted inserts, clazzio leather kit.
Old 12-05-2012, 09:58 PM
jlibert's Avatar
jlibert jlibert is offline
Vehicle: 2012 ram 1500 2wd express rcsb
Trim Level: express
Color: black clear coat
jlibert is on a distinguished road
not sure if cruise will work while abs is disabled.
07 rclb cummins. Efi live by silver bullet tuning
Old 12-05-2012, 10:19 PM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
I'm just gonna unplug it at the track and make a pass to see if it leaves and shifts any better with it disabled. With my luck I should probably trailer the damned thing to the track. lol
Old 12-05-2012, 10:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
FWIW I don't believe it effects TM at all, just abs and electronic stability control. So it still should help as far as cutting the throttle when the tires start to slip but I don't think it will have any effect on the shifts.
Sean
Old 12-06-2012, 01:12 AM
Rmfw Rmfw is offline
COPPA
Vehicle: 2009 Ram 1500
Color: Brown
Rep:13
Rmfw is on a distinguished road
if yall are talking about the speed sensor/ abs on the hubs yes it will affect the traction control and the abs. my engine light never came on just the traction control, esp,bas and abs... the dash glows with them on
Old 12-06-2012, 07:08 AM
NYTHWK's Avatar
NYTHWK NYTHWK is offline
Vehicle: 2012 Ram 5.7 CC
Trim Level: Express ST
NYTHWK is on a distinguished road
I went out and disconnected that harness as soon as I read about it on here. My throttle response was immediate and I layed rubber everywhere so I don't see how torque management still works. When I plugged the harness back in all the lights went out except for the chck engine light. But after turning the truck on and off a couple of times I noticed that the next time I drove my avg mpg wasn't reacting like I thought it should so I reset it. The next time I turned my engine on the chck eng light was out. If the results of performance by unplugging that harness is just a taste of what a tuner is going to do it then ill be buying a tuner for sure, sooner or later. But don't forget about the big thing about unplugging that harness, it disables your odometer reader on the dash but not to the ECU so there will always be a deviation if you do it.
Old 12-06-2012, 09:18 AM
snrusnak's Avatar
Rep:1385
pulling abs fuse will not effect odometer.
Sean
Old 12-06-2012, 10:13 AM
UNBROKEN's Avatar
Trim Level: R/T
Rep:123
Not the fuse...unplugging the ABS module itself.
I read somewhere else that effects the odo also but can't confirm.
Old 12-06-2012, 10:18 AM
snrusnak's Avatar
Rep:1385
Well it seems there are a few different conversations going on here.
Pulling the abs fuse.
Disconnecting a wheel sensor.
Disconnecting the abs module.
Sean
