Old 12-11-2012, 10:49 AM
Originally Posted by polvoson View Post
Spoke with the vendor today, they called Fabtech. Seems there is an 'improved" spring on the market, that supersedes the springs I got because in "some" cases the truck sits too low like mine.
New springs being fed exed. Will be here later this week. I don't suppose they are sending a tech to install them for me....?
Thats BS!
I think they just gave it to you knowing.....thats my honest opinion.
But glad they are rectifying the situation.
Old 12-11-2012, 04:52 PM
polvoson polvoson is offline
polvoson is on a distinguished road
I agree. It sucks. I'll see if they are willing to put them in. And they sold me air lift air bags that I specifically said need to work in this setup. They are 4-5" too short. So the truck has to sag at least 4" before it hits the bag. Unless they expand that much. But I doubt it. Never had air bags before.
Old 12-11-2012, 06:34 PM
Which did they sell you? Airlift?
Old 12-13-2012, 11:34 AM
Yes I bought the air lift bags. I can't see how they could work.
Old 12-13-2012, 12:09 PM
They work cause they compress outwards into the coil to prevent it from compressing.
Now what ever is not covered by the air bags will compress and it will sag a bit, but not as much without it.
Give your truck a bit of rake. 1" or so and add the bags, and when you load heavy things or tow heavy, you will more than likely level out
Old 12-18-2012, 09:45 PM
So fabtech sent new springs. I had the vendor install them. The truck still sags 1". Another words I only got 3" of lift. Looks stupid. I called fabtech. They said check it with the truck empty. Truck only has about 200lbs of stuff on it. I mean at this rate if I fill the tank it will sag. Still seems to me like the springs are too short and too soft. Is this normal?
Old 12-18-2012, 10:02 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
The Fabtech lift gives 5" up front and 3" in the rear....I posted that info '10 spring/summer in a detailed thread of every lift companies specs on their lifts
Kinda like bds and zone giving 4.5" front and a 3" rear option....then supplying a leveling kit 3/8" preload spacer wit the kit haha. Not even sure if its 3/8s, could be smaller
[CENTER][SIGPIC][/SIGPIC]
Old 12-18-2012, 10:03 PM
Many lift kits give you the option of 3" and 5" lift of rear coil.
Sounds to me like you got the 3".
Worst case you can always call Rough Country up and order their 5" rear coil and install it.
It will work, providing the shock they provided you allows for the additional travel.
I check their site (fabtech) and its hard to say whats included.....
Old 12-18-2012, 10:04 PM
Fack! you wrote this as I was typing.
But OP, there is your answer.
Call another vendor and grab their rear coil. I think RCX has em for $100. But you will get the lift you want. BDS or Zone is another option
Old 12-18-2012, 10:11 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2011 Ram 2500 Megacab Cummins
Rep:25
llsht14 is on a distinguished road
i did zone lift, 5" rear and bilstein 5100 in front, have about 3/4" rake
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
