Pro start remote started with DBALL bypass kit - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 12-07-2012, 03:29 PM
The Danimal The Danimal is offline
Vehicle: 2003 Dadge Ram
Trim Level: 1500
The Danimal is on a distinguished road
Default Pro start remote started with DBALL bypass kit
I have just installed a remote starter in my truck from canadian tire along with a dball bypass kit. I have followed all the instructions and have the wiring hooked up correctly. I am having some issues with it though. The remote start works perfectly fine after i program the remote and the starter and after the truck has been running with the key. after shutting it off and leaving it for about fifteen minutes the truck will only start briefly (about five seconds or so) and then shut off. It does this three times and then stops. once starting it with the key again it will do the same things again. i cant seem to get it to work properly. anyone with any experience putting these in that has any tips or direction on what i should do next would be very helpful.
Thanks
Old 12-07-2012, 03:32 PM
Resident Technician
Rep:1915
Sounds like the factory security system isn't being fooled into seeing what it thinks is the correct key and it's shutting you down. I'd call DB ALL for help.
Old 12-29-2012, 10:19 AM
namccanna's Avatar
namccanna namccanna is offline
Vehicle: 2013 Dodge Ram 1500 SLT
Trim Level: SLT Big Horn Edition
Color: Black & Chrome
Rep:50
namccanna will become famous soon enough
Did u flash the DBALL or did u have someone else do it?
I WELD FOR MONEY! IF YOU WANT LOYALTY.....BUY A DOG!
