Tires running really small?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 12-07-2012, 04:19 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
Thumbs down Tires running really small??
Yesterday I parked beside a jeep which had a set of 315 M/T MTZ (35's) and they didnt look as big as my 305x70R17 (34x12.00R17) Nitto Terra Grappler. the site says mine run true at 33.98. So i went out side and put a tape to them.. this is what I got..
Front
Back
I was thinking of putting a lvling kit on my truck and running 35's since I already have "34's" on them.. but idk now...
03 2500 ( Hemi ), 8" lift and 38" Toyo Open Country M/T
Old 12-07-2012, 04:21 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
Are you measuring from the ground?
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 12-07-2012, 04:24 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
yes i was... why?
Old 12-07-2012, 04:27 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
Looks like your fronts are showing more wear than the rears, combined with the fact they are holding up much more weight, that will make them look smaller.
Old 12-07-2012, 04:29 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
but almost a 1" lost because of weight??
Old 12-07-2012, 04:46 PM
APSTRAM's Avatar
Rep:89
It depends on wear and tire pressure. Maybe the tires you have were produced on the small side. Try to measue with the weight off the back tires and see what you get.
Old 12-07-2012, 04:52 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
its about 32 5/8ish
Old 12-07-2012, 05:00 PM
APSTRAM's Avatar
Rep:89
Yes. that is a bit small for unloaded tires of that size.
Old 12-07-2012, 05:07 PM
DirtyD's Avatar
Vehicle: 03 2500
Color: Gray
Rep:45
ya... so it has me wondering if i can run 35's with just a lvling kit
Old 12-07-2012, 09:25 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
It might depend on which tire you run. If clearance is tight you might get by with something like the Dick Cepek MC which runs small (just like the tires you have). But if you run somthing like a Toyo M/T or a Nitto TG you might have issues because they run a true 35" diameter.
Any way you go I think that you'l' have to trim a little to get 35's to fit with just a leveling kit.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
