Old 12-07-2012, 10:06 PM
DirtyD's Avatar
DirtyD DirtyD is offline
Vehicle: 03 2500
Color: Gray
Rep:45
DirtyD is on a distinguished road
Well I don't rub with the tires I have now, and have ok clearance. Ill try n get a pic tomorrow morning. But the tires I will be running when I do go to a 35's will be ProComp Xtreme All Terrain. they "say" they run 34.9
03 2500 ( Hemi ), 8" lift and 38" Toyo Open Country M/T
Old 12-09-2012, 04:18 AM
lenny09ram lenny09ram is offline
Vehicle: 2009 ram sport
Trim Level: sport
Color: deep water blue pearl
lenny09ram is on a distinguished road
i am running a 2.5 inch rough country leveling kit on my 2009 1500 sport and im running bfg at's 315/70r17 which are equivalent to 35's but they say they measure 34.6 and they do off the rim without air but once u mount them on a rim and fill it with air they buble out and actually shrink height wise. i thought the same thing when i mounted mine but they did actually loose about 3/4 of a inch once mounted. but full lock to lock i have no rubbing and i hit some trails and worked my suspension and had no issues.
Old 12-09-2012, 06:24 PM
CRANKYPISTOL's Avatar
CRANKYPISTOL CRANKYPISTOL is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
Rep:13
CRANKYPISTOL is on a distinguished road
All tires are not true to the size on the sidewall. I just bought 35" ATZ's and the website says they are only 34.5 OD. ALWAYS check MFG specs on the tire.
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 12-10-2012, 08:29 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Hmmmmm, can't explain the shortness of your tires unless the weight of the truck does indeed make that much difference.
As for 35s and a leveling kit, I have read where several people are running 35x12.50x20 on leveled pre-2006 trucks. It's actually pretty common. Google it when you have some time to sift through the results and I think you will find many owners that say it will run just fine.
Old 12-10-2012, 09:12 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
yes i was... why?
Then you are measuring a "loaded" tire..meaning the tire dia should be measured with no weight on it. Radial tires squat quiet a bit under load and that is why you are getting a "low" measurement. Try jacking it up to get the weight off and then measure.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
