Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 06-23-2013, 11:43 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Any updates here with pics? I have my Mopar cab lights sitting in the shop, but I'm scared to start drilling into the cab of my new truck!!
Old 06-23-2013, 12:08 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
I just installed them on my 12 3500 Longhorn. If you have the Mopar Kit just make sure you spend a lot of time getting the Template in the right place before doing any drilling
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 06-24-2013, 01:07 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Look threw the pics on the site I did a set on my 11 they turned out awsome
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 06-24-2013, 06:01 AM
Kcbigbadram's Avatar
Vehicle: 2014 1500
Trim Level: limited
Rep:497
I couldn't make myself cut into my brand new truck. I ended up having a shop do it since they were running a special on the lights anyways.
Old 07-13-2013, 02:43 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
no way could i drill into my brand new truck! i would leave that to the pros.
Old 08-09-2013, 06:06 PM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
I just did a set of the led smoked Recon lights on our truck. I have the dodge Oem template in a PDF file if anyone wants it. Light are very easy to install only thing I did different was used a smaller diameter hole for the wiring to pass thru and cut the plug of the lights then soldered them on the inside.
Old 08-24-2013, 05:17 PM
06blackram 06blackram is offline
Vehicle: 2007 Dodge Ram 2500
Color: Blue
Rep:29
06blackram is on a distinguished road
I'll take that pdf if you get a chance
Straight piped cummins blowin' smoke!
Old 08-26-2013, 04:51 PM
MBR MBR is offline
Rep:66
Originally Posted by skinnysfd View Post
sweet post some pics! im sorry i still have not got around to getting mine done yet.
PP me an email address and I'll send it to you
Old 09-03-2013, 11:31 AM
BrandonMski's Avatar
BrandonMski BrandonMski is offline
Vehicle: 2006 Dodge Ram 3500
Rep:24
BrandonMski is on a distinguished road
I've installed cab lights on a few 2nd gens. Although it was on 2nd gens the process would be virtually the same.
1. Drop the forward portion of your headliner enough to fit your arm in (you'll have to remove your HUD)
2. Remove your pillar covers
3. Arrange the lights how you want them to sit and trace them with something that's not permanent or damaging to your paint (map pen, pencil, etc.)
4. Also mark where the mounting screws and wire(s) will go through.
5. Drill small pilot holes for the mounting screws and a big enough hole for the wire(s)
6. Apply a small bead of chalking around the holes (as close to the holes as possible. this will avoid the chalk from mushing out the sides of the light)
7. Mount the lights
Now to the actual wiring
Note: all the aftermarket cab lights I've installed only had a power wire because it grounded to the mounting screws.
1. Find your power source. (I connected mine to the parking light wire in the headlight switch. So when my parking lights come on so does my cab lights. I've seen others run an independent separate switch but that is ghetto. I recommend you find a headlight wiring diagram but you can always use the process of elimination)
2. Connect the power wire to the power source.
3. Find a good place to run the wire from the power source to the the underside of your roof. (I ran through the dash, up the driver side pillar, and on top of the headliner)
4. Use T-connectors to tap the wire from the lights into the power wire. (I highly recommend capping and then taping off the end of the power wire. Some people don't and then it ends up grounding out)
5. Double check all your connections and test the lights.
6. Now time to put your truck back together, clean up, and enjoy your new lights.
I hope this helped. If you have any additional questions feel free to PM or email me.
2000 Dodge Ram 1500 Sport 4x4 - 5" lift, 36" tires, CIA, exhaust, CB radio, bed liner, undercoated, and more
2006 Dodge Ram 3500 Laramie 4x4 - trans temp, EGT, boost gauges, 5" exhaust, CIA, Fass 95GPH
Old 10-05-2013, 11:01 PM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2008 Reg. Cab/Bed 4x4
Rep:70
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
I had my body guy do it. He charged me 350, which was high, but I didn't have the time nor the desire to go cutting all those holes in my roof. I got some smoked Recons for Christmas last year and I have to admit they look killer. That said the connections need to checked and rechecked because I have 2 that are acting flakey 18 mos. down the road.
K&N Cold Air Intake, Magnaflow Exhaust, Rancho RS5000s, TRUXXX Leveling Kit, Heavy Duty Towing Shackles, Recon Smoked Cab Lights, Chrome Fender Flares, Stainless Door-sills, Chrome Door Trim, Atturo Trail Blade 35x12.50R20, METAL Grille Inserts.
