Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 12-07-2012, 10:00 PM
cruddymutt cruddymutt is offline
Vehicle: 2010 Dodge 1500 Big Horn 4x4
cruddymutt is on a distinguished road
Default New install, gauge leaking air
Got mine all installed today, very easy and straight forward. Took maybe 6 hours but my wife had surgery yesterday so I had to stop quite a few times to check on her. Very pleased with the system so far.
Question. I can hear a faint air leak coming from the back of the gauge. I recut the air line making sure it was good and square, still leaks. I tried wrapping the line with teflon, still leaks. Any other ideas for a fix or is my gauge possible bad? Would replacing the green plastic push ring possibly fix this? I have a spare Y fitting. Thanks.
Old 12-07-2012, 10:26 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Replacement Panel
CruddyM,
We'll send you a new gauge/switch panel on Monday. Please send yours back when you get the replacement so we can look at it.
If the leak magically stops over the weekend, please let us know, otherwise we're happy to replace.
FYI you're the first with this problem.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
Old 12-07-2012, 11:08 PM
Thank you very much. I tried to send a PM but can not with less than 25 post. I switched out the green plastic lock thing on the back and it still leaked. Aired it up to 10 psi and it was at 0 psi in less than 30 minutes. If I push in on the tube I can no longer hear the leak but I have to push it pretty hard and as soon as I let go, it starts again. Other than the gauge, Im very happy with the kit. Do you need an address? Thanks again.
Old 12-07-2012, 11:29 PM
TLC John's Avatar
Rep:17
We have your address. No worries.
Total Load Control™
Old 12-07-2012, 11:59 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Now THAT is some pretty good customer service right there! I for one am impressed!
Reps to you!
Old 12-08-2012, 02:23 AM
clum553946 clum553946 is offline
Vehicle: 2012 Ram Big Horn Crew 4X4
Rep:24
clum553946 is on a distinguished road
They are all about customer service!
Old 12-10-2012, 08:06 AM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
They are a very friendly and awesome company
Old 12-11-2012, 08:23 AM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
I do agree, there customer service is top notch. I make sure everyone who asks .. knows what i am using for airbags
Old 12-11-2012, 12:08 PM
Rep:40
I had to get my spring turned and my local off road shop. CVO in Burnside Nova Scotia was very impressed with the kit the bags and the compressor he got me to give them the website and he said he was gonna try one next time someone wanted new bags
